What would the disadvantages/advantages to using a 3/8" take-off tube/needle valve instead of a 1/4" setup for a Boka slant plate be???
The only thing I can think of is that the distillate take-off would be a little bit faster for use in pot still mode. Maybe, maybe not... idk...
ls
Yet another Boka Question
lacedspirits
Beat it to fit. Paint it to match.
Braz
Re: Yet another Boka Question
It is overkill. You simply don't need it. Running in reflux mode you are only going to be taking off a few drops per second and 1/4" ID tube is plenty big enough. After a little while you will build a separate simple pot still head for your boiler anyway (we all do). It ends up being easier and better than constantly trying to detune your Bok into a pot still.
Braz
- LWTCS
OFFTOPIC
Lacedspirits,
U running that Bok at work? Or just for personal use?
Noticed in one of your passed comments that your work rig had some issues.
Lacedspirits,
lacedspirits
The Bok is my personal still. At the distillery we have a PDA-1 and a larger 4" CM still from Mile HI with the crossed cooling lines running through the top of the column. The PDA-1 is nice but I'm not impressed with the Mile Hi still at all.LWTCS wrote:OFFTOPIC
Lacedspirits,
- LWTCS
U keep a smaller rig around for infusions and such?
lacedspirits
Yeah, Larry. I use the PDA-1 for our gins and vapor infusions.
