Shinners Flute build.
I thought I would post some pics as i progress. I have 4" pipe and 5 sight glasses built. I must say with Olddogs tutorial on making the sight glasses this was not nearly as hard as I thought it might be, I made these last night in about 1.5 hours. I still have 3 to make. I am waiting for my glass cutter and I think this will be the tricky part. I will be updating as I progress.
Kentucky Shinner
Kentucky Shinner
Re: Shinners Flute build.
I think they look great. Cant wait to see more copper porn!
ScottishBoy
HD Survival in a Nutshell...
Yup, lookin good KS.... Details and Copper Porn please, keep it comin man...
Great start....
Great start....
♦♦ Samohon ♦♦
ooooooooo son! ill be followin this!
I'll getcha my address so you know where to send it when yer done. I keep sayin Im gonna incorporate a sight glass into my rig, just for something to look at when Im sick of lookin at the numbers on the controller.
-Control Freak-
AKA MulekickerHDbrownNose
Find some cheep children's toy binoculars, use the lens as the port windows.Kentucky shinner wrote:I thought I would post some pics as i progress. I have 4" pipe and 5 sight glasses built. I must say with Olddogs tutorial on making the sight glasses this was not nearly as hard as I thought it might be, I made these last night in about 1.5 hours. I still have 3 to make. I am waiting for my glass cutter and I think this will be the tricky part. I will be updating as I progress.
Kentucky Shinner
If you don't know how to do it yourself, you don't have right to bitch, that you don't have any.
They would probably have plastic lenses, Just get a glass disc cutter from Ebay, they are cheap, and did a good job for me.todd54 wrote:Find some cheep children's toy binoculars, use the lens as the port windows.
OD
No idea is bad, just some are better than others.
Thanks for the input todd but I already have a glass cutter on the way.. Ordered it of ebay last week. Its like waiting for Christmas. I think Im gonna get back out in the shop tonight after it cools off some. I'll post picks on what I get done.
Thanks guys,
Kentucky Shinner
Thanks guys,
Kentucky Shinner
COoool maaann!,I'm jealous, take your time no rush at all to get quality.
Pretty work KS! your the man with a plan
#5559 -Take what you can and give nothing back... the great Captain Jack Sparrow
http://www.surplushed.com" onclick="window.open(this.href);return false;" rel="nofollow
For all your window needs....
ScottishBoy
that place looks pretty cool
what are you welding that with KY
Im guessing...a welder?Mr.Spooky wrote:what are you welding that with KY
Just solder will probably do...
ScottishBoy
i was just wandering if it was mapp, or oxygen / acettaline,,,,,, soft solder, or stick.
I used Mapp and soft silver solder on my Flute
OD
OD
Mapp that it works pretty good for me.
hey I bought a little mapp/oxy torch from craftsman a while back. That baby gets really hot. Cuts steel. oxy tank is same size as typical mapp tank. dont last too long, but its really handy. you probably dont need that though.
-Control Freak-
you cant use a lp torch head with mapp can you?
Thanks I have never seen this place.. I have a glass cutter on the way but if that does not work out I will order from these guys.ScottishBoy wrote:http://www.surplushed.com
KS
I think so . I have used propane when I have run out of Mapp so I am sure you can.Mr.Spooky wrote:you cant use a lp torch head with mapp can you?
yes, they are interchangeable. Mapp is propane/acetalyne mix.
-Control Freak-
did not know that,,,, thanks
do you got your delphlag condensor laid out yet K.S ?
yep I got it in my head. I still have to order two reducers for that.. hell I had to take it easy on the pocket.. I will order those next week... these damn coupling are like friggin gold.
KS
KS
that makes it kinda hard to push the "buy it" buttonKentucky shinner wrote:yep I got it in my head. I still have to order two reducers for that.. hell I had to take it easy on the pocket.. I will order those next week... these damn coupling are like friggin gold.
KS
But the mapp torch has a different jet, which makes propane burn even hotter than normal.MuleKicker wrote:yes, they are interchangeable. Mapp is propane/acetalyne mix.
OD
Kentucky shinner wrote:I think so . I have used propane when I have run out of Mapp so I am sure you can.Mr.Spooky wrote:you cant use a lp torch head with mapp can you?
Because of the different jets, it was my understanding that you could use propane with a Mapp head; but not Mapp with a propane head (which was the original question I think?).olddog wrote:But the mapp torch has a different jet, which makes propane burn even hotter than normal.MuleKicker wrote:yes, they are interchangeable. Mapp is propane/acetalyne mix.
OD
Is that the truth?
(ETA: Better quoting)
Last edited by therealraycharles on Fri Aug 27, 2010 8:34 pm, edited 1 time in total.
20L Stock pot
1 Gallon glass jar thumper
24" Liebig
24" Liebig
That was my understanding too.therealraycharles wrote:Because of the different jets, it was my understanding that you could use propane with a Mapp head; but not Mapp with a propane head
OD
