experience with Flavor
mammatried
Post by mammatried »
I am looking for some tips on adding some lemon peel to my thumper (standard mason jar is what i am going to use). lemon shine is one of my favorites and i would like to distil some myself and if i could switch out my lemon for some raspberry or peach midrun. (was thinking just unscreew my thumper give it a quick rinse and add my new fruit) want'n to see if yall had any info (amount of zest, size of thumper, ext...) for a newbie! Thanks Yall!
"Drinkn' To Gun Powder And Pussy, One Brings Us Into This World, The Other Will Take Us Out, But We Love The Smell Of Both."
Dnderhead
Re: experience with Flavor
Post by Dnderhead »
first DO NOT USE GLASS. a broken jar is not good in the middle of run. also the rubber seals can add a flavor you mite
not want.but otherwise adding fruit for flavors to thumper will work.the thumper should be about 1/4 the size of boiler.
how much you add depends on your taste and how strong the flavor is.
mammatried
good point on the broken glass I didnt think that would happen but good heads up. ill use copper. and if anyone can give me a typical amount of zest to put in my thumper id appricaite it yall. (dont want to over or under do good shine!)
blanikdog
Post by blanikdog »
I've found that to undershoot initially and work up next time is the way to go. I have overshot and added more neutral to reduce. It helps, but I prefer the other way. Once you have what you want it's repeatable.
Cumudgeon and loving it.
blanikdog wrote:I've found that to undershoot initially and work up next time is the way to go. I have overshot and added more neutral to reduce. It helps, but I prefer the other way. Once you have what you want it's repeatable.
Take that to the bank cuz Blanik don't take real notes.. Recon he done it a time or two cuz he remembered what he told you.
Happy Birthday Graham,,,,,,again. 2010 it is Sir :twisted:
