easy tri-clamp ferrule sight glasses
Re: easy tri-clamp ferrule sight glasses
Sorry about the two posts but that is the way this site is set up.
The last roll out would be the eye piece. A person could wrap and tape this so that they would know f their cut is accurate enough for soldering.
glass rolled.jpg (1.16 KiB) Viewed 2012 times
My thought on this was condensificator has a great tutorial but if you wanted to take the guess work out of fitting this might be an alternative. If this short tutorial gets some of you with more creative minds than mine then maybe we can put this to great use. This forum has helped me tremendously and I would like to share or give back some of my talents :egeek:
condensificator
Post by condensificator »
...or you could just use the link that i posted in the initial post that will do all of that for you instantly by inputting the pipe size without any software. http://www.harderwoods.com/pipetemplate.php did you see this? it spits out single-printer-page, tape-together templates.
Last edited by condensificator on Sat Feb 19, 2011 7:33 am, edited 1 time in total.
condensificator wrote:...or you could just use the link that i posted in the initial post that will do all of that for you in instantly by inputting the pipe size without any software. http://www.harderwoods.com/pipetemplate.php did you see this?
Yea, I looked at that and it is easier for the example I posted. What I was trying to do was promote ideas for layout maybe an Alembic Pot still with an onion shaped boiler but rather than do that layout I choose your design as a quick reference. May not have been the best place to post it, maybe I should just do a full layout pattern like the sheet metal people do. Thanks for your original post it is a great tutorial!
condensificator
...so, KS has a version of these complete on his site: http://www.hillbillystills.com/category_s/54.htm
even comes with borosilicate glass (pyrex/lab) and available with a copper sleeve pre-installed for those who find joining SS to copper tricky. wish he would'a had them up a couple months ago! can't believe how fast all of this stuff is progressing. HD rules!!!
Erichimedes
Post by Erichimedes »
Condensificator,
Great job on the tri-clamp ferrule sight glasses! This was my plan and I almost thought it was an original idea... You have some great ideas on the manufacture though.
My question is this:
I'm making a flute out of 3" stainless brewery pipe. Planning on 5 plates and sight glasses. I was planning on bringing the pipe into a machinist to cut holes for the sights, but I see that you've cut SS with a hole saw. The 3" I'm using is only 3/64 thick, so a hole saw is sounding like a better idea. Did you use any particularly special kind? I found some at the local hardware that state they're for "Metal/Wood" but don't elaborate. Any suggestions? Should I find a diamond hole saw?
hackware
Post by hackware »
luv it...!
yer tri-clamp sections are just what i was thinking of in my tri-clamp-still idea...
(funny how new ideas are usually rehashes of old ones...)
btw: you gonna put a plate in front of that sight glass (inside the section)...?
william...
ps. thought of doing a tri-clamp section of a boka take-off...?
tell me how hard it is to do... tell me how expensive it will be... just don't tell me what i can not do...
lead, follow, or get out of the way... ankle biters will be kicked...
•*´¯)¸.•*´¯)¤ª"˜¨¯¯¨˜"william..."˜¨¯¯¨˜"ª¤(¯`*•.¸(¯`*•
