Gave this bok a vinegar cleaning run today with 8L vinegar + 16L water. I used a few loops of ptfe plumbers tape to seal the connection between the keg and the still and it worked a treat, no leaks at all (thanks again to OD for the tip
The digital thermometer was steady at 99.5 celcius through the cleaning run, so the thermometer is within it's stated 1% tolerance.
I did notice the smallest amount of vapour escaping from the top, this happened both at 1L/min cooling flow (coolant output 47 C) and 2L/min cooling flow (coolant output 30 C) so I put a little bit of copper mesh in the condensor between the coldfinger and the coil to disturb the vapour path a bit and it worked a treat. After this there was no more vapour to be seen escaping from the top.
I have a couple of carboys of WPOSW that will be ready to strip soon in my pot still then I will get a couple more going to build up for a spirit run in a few weeks time. My next appointment however will the the token sacraficial run with some cheap cask wine
