Novice Guide for Cuts (pot still)
Re: Novice Guide for Cuts (pot still)
ive been reading and reading about the shots, heads and hearts, and i just cant get my head around it, ive looked for other literature and tutorials regarding it and have even had second thoughts about saying it because i know the answer is going to be read and research, but ive been doing that for months now, i built my potstill months ago and it is sitting there waiting to be ran..
Can someone please help me out?
Probably not unless you can ask a specific question. Best thing for you to do is run your rig, collect in small containers, and then use your senses to evaluate each container (diluted sample) at the same time as reading some of the lit. It'll probably be a lot clearer with a real world example in front of you.Kastro wrote:Can someone please help me out?
kiwi
Three sheets to the wind!
My stuff
My stuff
Run it and learn. You'll stumble around a bit and as long as you don't fall and get hurt, you'll be fine. This hobby is about the theory and the practice. That's why it's a perfect hobby. Good luck.
I do all my own stunts
ok, thanks guys, the biggest setback was understanding the cuts, but i guess your right, i should just get the finger out and run it..
Most, on reading your question, would refer you to Kiwi's _Novice Guide for Cuts_ but since that is the very thread you have posted to, I assume you have already read it. You have, haven't you? Fine tuning your cuts, by taste, smell and even feel, is an acquired skill. It takes practice and experience. And to some extent a decent innate sense of taste and smell which not all of us have (me, for one).
Here is a really rough guide for a pot still run. It is what I use for starters. Collect your run in small increments. Number the jars. Take your run down to about 20%. Calculate the total amount collected. The first 3% of the run is foreshots, the next 17% is heads, the last 20% is tails. What is left, the middle 60%, is hearts.
Now, working from the hearts portion out, you can start sampling the jars that are in the transition zones to decide if you want to add them to the hearts or not.
Keep in mind, the above is a VERY rough guide. The percentages will be different depending on a lot of variables; your mash, how you run the still, your taste, etc.
That help any?
That help any?
Braz
Nice post Braz.
Just do it.
Just do it.
I don't know how to save a thread, so I'm just going to comment so I can find it in my posts later for reference...
Depending on what view you are using. But either upper or lower left corners there is a bookmark button. Then you can find your bookmarks in the user control panel.
Won't be too long and this method won't work anymore either. Keep piddling and it'll all start to fall into place.BrewVegas wrote:I don't know how to save a thread, so I'm just going to comment so I can find it in my posts later for reference...
Very true WalkingWolf. I remember thinking that when I first came here. Now I can't find a dern thang.WalkingWolf wrote:Won't be too long and this method won't work anymore either. Keep piddling and it'll all start to fall into place.BrewVegas wrote:I don't know how to save a thread, so I'm just going to comment so I can find it in my posts later for reference...
Not much point looking further than the information at the beginning of this thread......its by far the best Ive seen anywhere.Kastro wrote: ive looked for other literature and tutorials regarding it
I to was confused about cuts until reading Kiwis Guide and then running my still.........it all begins to fall into place after that. With practice it gets better and easier the more you do it.
Thanks!!!Prairiepiss wrote:Depending on what view you are using. But either upper or lower left corners there is a bookmark button. Then you can find your bookmarks in the user control panel.
Your welcome. Now if I can just get myself in the habit of using it. I mite be able to find some things I want to.BrewVegas wrote:Thanks!!!Prairiepiss wrote:Depending on what view you are using. But either upper or lower left corners there is a bookmark button. Then you can find your bookmarks in the user control panel.
I had a hard time wrapping my head around this at first. You can try and explain it to me till your blue in the face but until I put my hands on it this did not really sink in.
“A way” that helped me out, was to do a 5 gallon Spirit run of 35-40% UJSSM. Using Kiwi’s excellent guide as the way forward, I separated into a metric ass ton of jars. Tasting and smelling everything and leaned heavily on the stick for percentages.
Once comfortable that I made some pretty tight cuts, I took all of the heads and tails from this run and threw them right back in the still with the UJSSM dunder and started running again.
Everything came out more condensed (no pun intended). The heads were super strong smelling and tasting. Once I got to where the hearts would have been the still slowed drastically and picked up again as soon as the tails started kicking in. This gave me some confidence in my process. And as an added bonus, you pick up some really, really tasty hearts on this run too. Now that I knew the smell, I got some good sipping stock.
Now I had a clear understanding of the smells and tastes that I do not want in my drink. I even went so far as to keep 2 jars of heads and 2 jars of tails so that I could go back and verify on future runs until I got more comfortable.
Having the point of reference helped me, maybe it can help someone else. I am by far no expert, but my drink is getting better every run. I feel that I can now make descent cuts and a lot less jars to do it. I am getting more in tune with what is coming out the pipe.
If you look like food, don't be surprised when you get eaten.
great guide and very helpful for the beginner
I think some of the best advice is to not be greedy with the cuts. If there is a particular jar that is questionable, leave it out of the sipping stock. If there is a jar or two that is mostly hearts but a little heads (or tails) mixed in, I'll use it for an infusion, or mixer (made a great tasting apple jack). Hell, even throw some oak chips (not sticks) and let it age and give it as a gift to those who immediately mix it with ginger ale when you give it to them....they're happy for the gift, and your happy they didn't mix your pride and joy with ginger ale .
Thanks, you made the consept very easy to understand.
Hell, the "Concept" I got! I could write a book on the "Concept" of making cuts....shiner153 wrote:Thanks, you made the consept very easy to understand.
The real life art of doing it is where I screw it all up!
Everything I do or say may or may not have really happened... or it may or may not be all bull shit!
Turning money into steam and likker 10 gallons at a time!
I just want Uncle Sam to be more like Uncle Jessy!
Hey guys I've read through this post numerous times and I learn something new each time. But I am still confused on a stripping run. I'm using a pot still and I understand this is a fast run but what temperature do you run it at? Do you collect all that comes out and just re distill it?
Don't worry about the temp. Collect it all, dilute to 40% and redistill.UKwildcatshiner wrote:Hey guys I've read through this post numerous times and I learn something new each time. But I am still confused on a stripping run. I'm using a pot still and I understand this is a fast run but what temperature do you run it at? Do you collect all that comes out and just re distill it?
WalkingWolf wrote:Don't worry about the temp. Collect it all, dilute to 40% and redistill.UKwildcatshiner wrote:Hey guys I've read through this post numerous times and I learn something new each time. But I am still confused on a stripping run. I'm using a pot still and I understand this is a fast run but what temperature do you run it at? Do you collect all that comes out and just re distill it?
Except make a foreshots cut. Or make sure you make a big enough foreshots cut on the spirit run to cover the original amount of wash used in all the stripping runs combined for that spirit run.
Dilute it with water?
Yes, distilled water.UKwildcatshiner wrote:Dilute it with water?
Distilled or good RO filtered water if you are diluting for drinking.King Of Hearts wrote:Yes, distilled water.UKwildcatshiner wrote:Dilute it with water?
If diluting for a spirit run any water will work.
I love this thread. I am just getting into distilling seriously and while I feel like I have a pretty good nose for spirits I had no clue where to even start with cuts.
Great post, Kiwi.
Great post, Kiwi.
Just getting started, trying not to be another idiot building a poison mill.
So made my first run last night using sweet feed.... I calculated the wash abv to 6.8% and the wash is only 4.5 gallons the the other .5ish galllons being used up in the 5 gallon bucket by the volume of sweetfeed and sugar
Calculations
3 gallons actual wash liquid amount = 384oz
384oz x .07(7%) = 26oz <-----Is this the total ethanol present in this wash
I collected in 8oz jars (assuming way to big) and collected 15 jars, the first was allocated forshots (roughly 200mL)(which I only should have collected 90mL's) (and it came out greenish and REALLY BAD SMELLING CLEAR YOUR SINUSES STUFF)
I havent tried the jars yet since it's way to early but they have been airing over night...somewhere around jar 5 is spectacular, and as I kept going it just got what seemed heavily watered down but was mostly great!! I literally could have "wheezed the juice" it was so good
So from my calculations, since I don't have an alcometer I should have only collected 28 oz which makes that 3.5 jars(each 8 oz) total??? that doesn't sound right
Some help please
after recalculating and doing some math... I will be throwing these back in with another wash charge...collecting 180mL forshot (6 gallons) and redistilling collecting in 4 oz intervals
*sigh* oh well, it's a learning curve
Calculations
Some help please
From my calculations.
3 gal @ 6.8% ABV has .204 gal (26.112 oz) of 100% alcohol in that 3 gal.
Your not going to collect at 100% ABV or 100% of the alcohol. I'm guessing you are using a pot still? You didn't say.
So if you collected at an average of 50% ABV that would be .408 gal (52.224 oz). Give or take.
If collected and average 40% ABV that would be 65.28 oz. 60% ABV would be 43.5.2 oz.Give or take.
Another thing is if you add it to your next wash to run again. Without knowing the ABV of what you add in? You will have a hard time figuring out what ABV the still charge will be. And how much to expect to collect. This is where the alcohol meter would be real handy.
I only figuring this stuff out to make sure I have enough jars to collect all my product. What I get out of the still well is what I get out. It's not going to be specific. And each still and how you run it will be different.
maybe this has been posted already but i will ask it anyway,
how many times can you keep putting back the heads and tails into the pot for another run before you are wasting your time and energy?
thats putting it back in the pot with a fresh wash/mash stripping run,
Well you are always going to have usable ethanol in your heads and tails, I'd say that means you should add them back indefinitely. I know that a lot commercial distilleries do this. Some even add foreshots, although I doubt I'd mess with that.
