Looking around, I haven't been able to find any discussion about using a turkey fryer kit as a boiler. Something like [http://www.amazon.com/dp/B004070Q9E] seems ideal - stainless steel, heat source with a good fit included, flat top to put a flange on, included thermometer to monitor the wash's temperature...
Is there a reason not to use a setup like this?
Turkey Fryer for boiler
Re: Turkey Fryer for boiler
i use the burner on one of those, but truthfully the pot is still in the box, i havent really looked at it. i thought they were aluminum. i should get it out and make a big kettle of chile.
today marks the dawn of a new error.
pot with mine is alum also....makes a damn fine deep fried turkey....and the chile is sounding good too! if the pot is stainless id say go for it but a domed top is more suitable to vapor stream
3' Essential Extractor PSII High Capacity (Brewhaus) on gas,recirculating 60 gal olive barrel for cooling
Employ your time in improving yourself by other men's writings, so that you shall gain easily what others have labored hard for ~ Socrates
get a keg. You'll like it better.
the burner is fine tho...
this is the internet
