Mashing vs Sugar
stillenand chillen
Mashing vs Sugar
Post by stillenand chillen »
Been reading and trying to figure out if mashing is cheaper than using sugar. Trying to figure out a grain bill for a 25 gallon wash. Need to know how much corn and malted barley I would need in pounds. If anybody could point me in the right direction or better yet just give me the answer :ebiggrin: we would be much appreciated.
Ask me no questions and I'll tell you no lies.
Washashore
Re: Mashing vs Sugar
Post by Washashore »
Sugar is definitely cheaper. Here is a recipe calculator.
For a 25 gallon batch, your looking at anywhere between 50 and 80 lbs worth of grain.
EDIT: just plugged in "45 lbs field corn" and "35 lbs Briess 6-row brewers malt" ....this should result in a 1.080 original gravity (1.020 final) for an 8% potential ABV wash.
stillenand chillen
Thanks so much for the calculator. That's awesome! Kinda what I figured. Just wanted to make sure. I figured something like 40 lbs of corn and 12 lbs of malted barley. My local brewing supply store quoted me $65.00 for a 50 lb bag of crushed two row malted barley.Just thought it would be fun to mash grains and not use sugar. Well I guess I dont have to build a mash boiler anymore. :(
Washashore
You should at least try it. I love mashing grains. You can always use the spent grains for a sugar head anyways. Check out http://www.50poundsack.com" onclick="window.open(this.href);return false;" rel="nofollow. Free shipping in US.
stillenand chillen
what do you think on my grain bill, am I in the ball park? or can you fine tune it a little, I realy was psyched about building a mash barrel, I have a 30 gallon stainles steel drum just sitting around and I was going to put a false bottom in it
Washashore
According to the calc, you should end up with a bit over 5% ABV. Personally, I'd add a bit more barley. I'm still relatively new to the all-grain thing myself so maybe others can chime in if this calc is off. It should make a fine likker with the recipe you have.
Personally, I wish I had a 30 gallon stainless drum laying around. I once searched for them online and couldn't find anything under $400
astronomical
Post by astronomical »
have you done all grain beer before? if not than I'd think that learning with 30 gallon batches could be costly. Theres A LOT to learn.
stillenand chillen
no still reading, You might have a good point maybe I will rethink using the 30 gal. drum and learn will a smaller size. I have a 15 gal. keg that I could turn into a brew kettle and a 7.5 gal keg I could use for a boiler and a pot head still.
junkyard dawg
Post by junkyard dawg »
pretty steep for 2 row...
My buddy just got a sack of 6 row for $40. Not sure if that price is available online, but worth checking out.
I agree about starting small on all grain. There are lots of things to learn...
It is super fun tho... and the results are spectacular. :thumbup:
this is the internet
NcHooch
Post by NcHooch »
Washashore wrote:Sugar is definitely cheaper. Here is a recipe calculator.
Heh .. practically speakin, I wouldn't dare go over 35 pounds of corn and 15 pounds of barley for a 25 gallon batch ...and i'd definitely recommend you work on a few 5-gallon batches at first.
hope that helps
NChooch
NcHooch
Post by NcHooch »
I forgot to add that you could prolly do a 25 gallon batch for 25 bucks (all grain, cracked corn from the feed store and a bag of 6-row )
I haven't priced big bags of sugar lately but a 25 gallon batch of UJSSM is gonna take 35 pounds of cracked corn and 35 pounds of sugar. (this will yield more likker that the AG recipe though)
NChooch
rubber duck
Post by rubber duck »
Who cares what it costs, all grain is better.
At this point it's probably the same for me, I can get a 50lb sack of dextrose for 28 dollars or 100lb of corn for 30 bucks.
MitchyBourbon
Post by MitchyBourbon »
As far as your recipe goes:
You need about a diastatic power of 30 per pound. You have 52 pounds so you will need 52 * 30 is 1560. 2 row barley malt has a diastatic power of 140 per pound. You have 12 pounds in your recipe so 12 * 140 is 1680. That should be just fine.
I would have to agree that starting out doing a single mash with that much corn is a bit ambitious. Probably a very good recipe for frustration. You can still use your 30 gallon boiler with a smaller batch say 7 to 10 gallons. You might also consider using flakes corn, It's a lot easier than cracked corn. Flaked corn is pre cooked so you don't have to boil it.
Cheers
MB
I'm goin the distance...
