My First Still....So I went Big!!!!
ProChargedHarley03
Re: My First Still....So I went Big!!!!
Post by ProChargedHarley03 »
Lol!!! No not pregnant!!!!! Had a little to much fun on the procharged Harley!!!
Yep!!! I have a drain on the parrot that I keep open to get rid of the fores!!!
Thanks for the link Richard7 I should be running stubby this Monday!!
God speed on you're run!!! :wave:
hendecp
Location: Planet Earth, western hemisphere, in the "lower 48"
Post by hendecp »
ProChargedHarley03 wrote:Lol!!! No not pregnant!!!!! Had a little to much fun on the procharged Harley!!!
So, I'm curious and have been following this thread. Did you ever get "Stubby" fired up and running this past Monday?
Wherever you go, there you are..... But, where am I and how did I get here???
ProChargedHarley03
Hi, hendecp!!! I will be running it in the morning!!! been real busy :thumbup:
hendecp
Post by hendecp »
ProChargedHarley03 wrote:Hi, hendecp!!! I will be running it in the morning!!! been real busy :thumbup:
We'll be running in tandem then! I plan on running tomorrow morning too! Good luck! :thumbup:
ProChargedHarley03
well it starts again!!!!!!!! :clap: Gen1 os UJSSM!!!!! Here are a few pix :thumbup:
Man my rack makes filling the boiler super easy!!!! :clap:
A guest star showed up to help on this run!!! thanks howard :moresarcasm:
hendecp
Post by hendecp »
Good deal man! Not sure about the Stern placemat.... :eh: your parrot setup is sweet. How warm is the distillate when it comes out into the jar? I may do a little coil setup of of the take off instead of a Liebig. I ran my mash this morning and collected about a gallon (US). My first real run, it was pretty exciting! :clap:
ProChargedHarley03
Awesome hendecp!!!! i just put 1/3 of my backset back in, and im adding sugar now!!!! i have had that book for years!!! i needed a little more space and when i opened the book box he was the first book!!!!!! :lol: my strip run filled up a 3 gallon carboy, that will be added to my gen2 run, so i only proofed the first jar. it was 138, but i did add a half gallon of 80% to the 12 gallon run. with my still short "potstill" The parrot runs hot, about 152 degees but runs 120-116 with the plate trees on it :clap: alot more copper in between the boiler and the head :lol: I also have a drain on the bottom of the parrot that i open at first to collect the foreshot, so i can pitch it!!!!
good job on you're run. an "always" have fun and be safe!!!
Backflush
Post by Backflush »
Pitch you forshot? Are you not supposed to save it and throw it back in with the next run. Hmmm, maybe with a high efficiency column that is not required.
hendecp
Post by hendecp »
ProChargedHarley03 wrote:Awesome hendecp!!!! i just put 1/3 of my backset back in, and im adding sugar now!!!! i have had that book for years!!! i needed a little more space and when i opened the book box he was the first book!!!!!! :lol: my strip run filled up a 3 gallon carboy, that will be added to my gen2 run, so i only proofed the first jar. it was 138, but i did add a half gallon of 80% to the 12 gallon run. with my still short "potstill" The parrot runs hot, about 152 degees but runs 120-116 with the plate trees on it :clap: alot more copper in between the boiler and the head :lol: I also have a drain on the bottom of the parrot that i open at first to collect the foreshot, so i can pitch it!!!!
Good deal man! I just started my first UJSSM, true to the nut,recipe today. I should be running it by Tuesday morning. Can't wait! This is addicting! Anyway. I am working on my parrot and your giving me some good ideas! I do however want to cool down the take off before the parrot as to get accurate readings on the fly with the parrot.
This sure is fun!
ProChargedHarley03
It sure is a blast!!!!! I was going to do a mod with my parrot to
Cool it!! But after a few runs I got the hang of using the hydrometer
As a baseline to help me with my cuts, Once I toss the fores
And start collecting, the first jar will be the highest ABV% so I
Write down that number, and little by little the number drops and the hydrometer
Rises higher and higher, after it drops about 50% from the starting number, and it starts to get the
Wet cardboard smell, I shut her down. Once you get you're fermenting
Down and you're still locked in, you're runs will be consistent with ABV% if you
Don't add any heads or tails to the run!! Then if you want to bump up the proof a bit, toss you're heads and tails in
In the boiler at the start of the run to bump up the ABV% up 20+% at jar #1!!!
Richard7
Post by Richard7 »
Backflush wrote:Pitch you forshot? Are you not supposed to save it and throw it back in with the next run. Hmmm, maybe with a high efficiency column that is not required.
Hey Backflush. :wave: Yep, you always pitch the foreshots but that's not much. The fores are the very first to come off and it has the bad stuff in it (methanol, acetone and other nasties). I always toss the first 300 ml (just over a cup) on a twenty gallon run(of wash not spirit!). The heads and tails is what you add back in or save for a spirit run.
PCH I finally saw your parrot drain in the vid you posted. :thumbup: That is a cool way to handle the fixxed parrot. Mine is loose so I just add it in. Its Saturday morn now so I will be adding it in in just a little while! Another batch of Rads all bran.....
ProChargedHarley03
Sweet!!! Richard7!!!
Sorry backflush I didn't see you're post;( you don't want to
Add the foreshot to you're next batch!!!! You can save it and use
It as lighter fluid or cleaning solvent!!
Like always, have fun and be safe;)
hendecp
Post by hendecp »
ProChargedHarley03 wrote: You can save it and use
It as lighter fluid or cleaning solvent!!)
I can say that it works great for stripping wood. Found that out the hard way yesterday! It took some paint right off of my workbench..... I might actually use the foreshot jar for stripping the finish off of some wood today.....
ProChargedHarley03
Oh yes nasty stuff!!! The very first run I ever ran I did the proofing
On an antique table, lets just say it needs to be re-finished now.... :oops:
ProChargedHarley03
Oh i think this is going to be a great summer!!!!! :esurprised: 1 1/2 gallons of Apple Pie!!!!!!!!! Check :lol:
ProChargedHarley03
Running Gen2 today!!! it's going to be a good day!!!! toady is the day i get to take a drink!!!! :thumbup:
Richard7
Post by Richard7 »
I was feeling a little toady today too, till I had a drink! :D LOL Had to slam on the typo. Hope you like the fruit of your labors! Let us know how it was!
hendecp
Post by hendecp »
ProChargedHarley03 wrote:Running Gen2 today!!! it's going to be a good day!!!! toady is the day i get to take a drink!!!! :thumbup:
Good deal! How'd it turn out? I just started gen 2 in the fermenter today with a 3rd of gen 1!
Fastill
Post by Fastill »
You sure did an awsome job using an offset head as a deflagmater and a product condensor for a flute design!!
I am reading your results and waiting to see how you like your results to see if I need to start looking for sight glasses and making a plate tree for my offset head setup. Just seems so simple the way you did it. :thumbup:
ProChargedHarley03
hello all!! Richard7 thats funny...ooopppss :thumbup:
hendecp, the run went great!! i put all of the 3 gallons of gen1, in the gen2 run. jar #1 started off around 70% ABV, i stop collecting when the vapor temp hits 200F, I collected another 3 gallons. I'm running as a pot still and will be saving up heads and tails for a jekell and hyde run!!! "my still with the plate tree" :thumbup:
Fastill!!! this setup works great!!! I am real happy with it. i only have 2 run with the plate tree, and i got some good numbers!!! i posted that run and some pixs.
one key thing i have learned, is not to try to run you're still to hot or too fast, in the past with some of my first runs, i would run my boiler real close to 200F the whole run. i found out this would make my heads and tails cloudy :cry: Now what i do is get my boiler to temp "full power with my MK5500" when i get the first drip of foreshot i turn down my power to 12Amps and keep it there the whole run, this works great for me. now all of my runs are crystal clear :clap: Distilling is not a race, I found out the hard way!!
Thanks all for the good words, and always have fun and be safe!!!!
ProChargedHarley03
Gen3 of UJSSM is in the boiler!!!!!! So here we go!!!! :clap:
Richard7
Post by Richard7 »
So.... how was it? Worth the wait? I personally love the part where you take the hangover off first and throw that away! (unless you really over do it :sick: !) I've got to give you credit for waiting. Is your UJSSM coming off with allot of flavor? Does the flute make it very neutral? I saw the numbers, but I am curious about the flavors of the different (Dr. Jekell and Mr. Hyde) ways that you run. :thumbup:
NcHooch
Post by NcHooch »
ProChargedHarley03 wrote:Oh i think this is going to be a great summer!!!!! :esurprised: 1 1/2 gallons of Apple Pie!!!!!!!!! Check :lol:
Yumm !!
NChooch
ProChargedHarley03
oh yes very smooth stuff!!! oh it has flavor!! but it will take me awhile to get use to it :D i'm just pot stilling on these runs, once i get a bunch of heads and tails
i will run with the plate tree added to stubby!!!! :clap:
i got a bunch of med char white oak chips :thumbup: so time to let 3 gallons sit for a few months!!!!!
ProChargedHarley03
well its been 10 months since i have had a drink!! so today was the day :esurprised: and I must say it is hands down one of the best feeling to drink a great tasting whiskey
that i made with my own hands!!! I want to thank everyone on home distiller forum that helped me produce a great whiskey :clap: i want everyone how reads this post to know that
UJSSM with white oak chips let sit for a week filter and mix with coke zero.........Delicious....wow!!!!!! i will never buy whiskey ever again :clap:
This is UJSSM 130 proof in a makers bottle!!! soaked in white oak chips for only a week!!!!! WOW!!!!!!! Damn good!!!!
ProChargedHarley03
ProChargedHarley03 wrote:well its been 10 months since i have had a drink!! so today was the day :esurprised: and I must say it is hands down one of the best feeling to drink a great tasting whiskey
that i made with my own hands!!! I want to thank everyone on home distiller forum that helped me produce a great whiskey :clap: i want everyone who reads this post to know that
ProChargedHarley03
I will be Distilling Gen5 this weekend!!! I am planing on
Going to 7 or 8 Gens with my UJSSM!! Then I think it's
Time to do " all grain" corn rye and barley!!! :thumbup:
Richard7
Post by Richard7 »
I hear ya on the never buy whiskey again :clap: . Although I am going to have to make a trip up to Iowa on a plane soon and I don't think they will let me board with half of a gallon of my home made stuff :thumbdown: ! I am going to have to find something I can buy at the liquor store that takes the time to cut heads and tails, instead of continuous distillation and I'm sure that will cost me pretty penny. Anyone have any suggestions? PCH have you tried your apple pie? I just love that stuff but only in small amounts, It's way too sweet to just keep on drinking but it sure is good for dessert!
ProChargedHarley03
Oh yes, it's like a after dinner mint......but different.
It is sweet, I will be drinking it on cold nights, to warm me up!!
I was just amazed how good my UJSSM was after few days on
White oak chips!!!! Very happy!!!!
ProChargedHarley03
This is what I get, Every 13 gallon run!!! This is Gen4 of 7 runs of UJSSM!!! I have been busy!!!! :clap:
