what I learnt to get supirior product from a reflux still..
Lynx_Gen
Post by Lynx_Gen »
So, over the last lil while, I've had several runs under my belt.
I always tried to "Make cuts" separating into separate containors about every so bit, (roughly about evey 100mls.) I could tell the differance between heads n tails, but could never realy find a clear cut sense of presance of the hearts.
It was always kinda blurred together, and I would take what i found to be the best smelling/tasting bits from the middle and toss em together. (I have a small unit, it doesnt produce much each run.)
So the other night I was did a run, and ended up with a low return, (Aproximately 2/3rds of what i would usualy get, before it weakend out and smelled/tasted like cardboard.)
I think it was cuz I reduced the amount of sugar somewhat, due to the length of time my ferments were going.
As it is, being slighty disgusted, I ran it wide open for another short period. I had another run to do yet, and figured I'd just dump the previous into the next one. and thats what I did.
I pulled the usualy amount of foreshots with each run, which in my case I take off almost double whats recomended.
What i found was on the second run, I could run MORE heat. Also what I found was there was a much more clearer distinction between heads hearts n tails.
I had this wierd fear that I would loose out overall, but in the end, I seemed to have gained.
This is prolly largely due to at the end, when I got a little bit into the tails, I just let her run for an extended period of time, and mass collected it for the next run.
I found a big difference, and a clear cut distinction between the cuts. I ended up with a product 4 times better than any of my previous runs! OMG! Its like day and night comparison.
Point is, to anyone runnin a small unit, try this, do a double or triple run, tossing the previous runs product into the next one, you'll get a far supior and much better and satisfying product. its very well worth it!
I think I'll be making a pot still soon to do fast stripping runs, that or adapt the boka to transform into a pot still.
so anyone else have a similar experience, or am I just imagining things?
:D
~L~
To quote RumBrewer from a thread i read:
"Read #8
It should say... All plastic or synthetic material is considered to be unsafe unless NASA and GOD prove otherwise!"
Richard7
Re: what I learnt to get supirior product from a reflux stil
Post by Richard7 »
+1 on the sugar amount = to your lower yield. You can add the heads and tails in your next run or save them up for a spirit run. Just be sure to dilute what you are going to redistill down to at least 40% ABV.
guittarmaster
Post by guittarmaster »
yeah, i agree. it seems the more I recycle my heads and tails the more defined the transitions are.
GM
War is Peace
Freedom is Slavery
Ignorance is Strength
Great post for the stove top crew. WTG.
OlympicMtDoo
Post by OlympicMtDoo »
I agree completely, I do all double runs for my neutrals even using a 16 gallon keg, cuts are much more obvious the second run.
Rod
Post by Rod »
I have a small still , 5 litre super reflux , purchased before I read anything here
however, I only make neutrals and gin ( using a parrot for infusions ) which I redistill ,without anything in the column
to the point of my post
as I do each 5 litre run , I keep the first 50 ml , which I add to the next 5 litre run
and then on the final run discard the 50 ml
works for me
I also have a heater control devise and can control the distillation rate , particularly at the start
makes the first cut very clearly defined
the final cut is when the temperature starts to rise at the end
The Friendly Spirit
