I run a pot for bourbon, rum and soon to be single malt and have a question regarding the changes from heads, hearts and tails. Typically I run a heavy load of wash for say rum, about 20 gallons which strips down to about 12 gallons of low wines. Haven't averaged the abv on my strip but came out with about 7-1/2 gallons of 70% after cuts to age.
My question is, my heads on this run came to about 4-1/2 quarts, hearts about 5 gallons then at about 60% tails came rather quickly going from 60% to 35% in about 3 quarts. Is this typical for a pot still? I'm curious if this is normal or do I need to tweak the way I run my still. I start off with a pretty heavy stream not separating the foreshot as I know I'll just use the first three quarts for cleaning solvent anyway so why toss what will be used. When I get the first quart to quart and a half I tone the stream down rather this and run this until my still tells me to turn up the heat (usually at about 65%) I try to maintain this output through occasional adjustment until I find 40% coming across. Usually I collect down to 30% and shut it down. I'll hold on to the tails and use them in my cuts. They never taste or smell off but seem just watered down. My 30 gal wash for rum after good cuts seems to yield about 5-1/2 gallons of 70% proofed down to age by barrel.
Typical for a pot still?
Pot Still Question (Cuts)
DFitz
