Hi folks, appreciate any help I can get.
I am running a 36 quart SS pot still with a coil condenser making mostly fruit brandies and false brandies with good luck, but I am still a novice.
Last week I ran two batches of submerged Cabernet pumace and got a very tasty grappa. After discarding foreshots the yeild was so low that I only had about 4 pints of distillate above 40%abv (tasted great to me on first run) and about 5 pints of under 40% down to maybe 20%. It smelled good so I re ran all the feints and then mixed the product in with the rest, based just on smell with out tasting. (big mistake)
Now the grappa has a nice flavor up front and a really mean bite at the end, tastes like chewing on concentrated grape seeds, and leaves a taste in my mouth the next day and my ears ringing. (more so than most grappas I mean)
I have now read almost every post I can find on grappas and have some idea of what I did wrong: greedy novice not cutting tails being the main sin.
My question is more about saving this batch. I poured it through a coffee filter with some activated charcoal sachets at the bottom, and am continuing to air out with coffee filters on the mason jars. It has improved, but at this rate it will take years. I understand that this is a common problem with grappas and greedy novices, but what would you suggest, cold filtering, re- running all and discarding tails? I don't want to lose that grappa flavor if I can avoid it.
Thanks in advance,
-Thirsty
grappa from cab pumace help please
