strawberry panty-dropper
Re: strawberry panty-dropper
I was under the impression you were supposed to do that anyway,,you keep adding more alcohol to the fruit until no more flavor.then mix/mach all together.
Exactly, you keep adding more alcohol to the fruit until the panties fall down
- Truckinbutch
Hopefully with the owner of the panties still upright and willingjimdo64 wrote:Exactly, you keep adding more alcohol to the fruit until the panties fall down
Willing yes.... Able yes...Upright dnt care!!!
Love it...going to have to use something similar.jimdo64 wrote:Anyone need a label for their bottle...
Someone PM'd me for a Raspberry PantyDropper label. Here ya go. Cheers.
Here try this one, had a few seconds to clean it up in photoshop
Cheers
Cheers
so with all the people and all the different likker/fruit options...
your best jar consisted of????...
What Fruit did you use.. Frozen Fresh..???...
Clear Brandy...
Did anyone try just off shelf store??? what about the "colored" or only clear??
Vodka...
Personal batch or store??
Everclear...??
Just trying to summarize since we not have almost 30 pages to run through.
Clear Brandy...
Vodka...
Everclear...??
- Truckinbutch
jimdo64 wrote:Here try this one, had a few seconds to clean it up in photoshop
Cheers
My post was 1-2 pages ago, I tried several fruits. The best was definitely the frozen strawberries. Pears don't yield much syrup. Canned peaches that were frozen and thawed in the alcohol are probably 2nd best. Lots of syrup but not much flavor like the strawberries. Pineapple tastes good but after a couple of weeks with little syrup formation I had to pour in a cup of boiling water and shake it around to "forcibly" extract the syrup. Blueberry and blackberry are coming along nicely but take more time. Strawberry is definitely cheapest (I got a 4lb bag of frozen ones for like $8) and also work the fastest. I used 65-70 abv neutral (birdwatcher's sugar wash).clcperrys wrote:so with all the people and all the different likker/fruit options...
Clear Brandy...
Vodka...
Everclear...??
Away with yer pills, it'll cure all ills, Be ye Pagan, Christian or Jew,
so take off your coat and grease your throat with a bucketful of Mountain Dew.
Jimdo64 The labels are great. thanks for sharing.
SPD is Great!
My first experiment with SPD I made 1 qt and 2 pt of strawberry, 1 qt of blueberry and 1 qt and 1 pt of pineapple:
The Blueberry I used UJ (100p) took a little longer but it is for me only so thats ok. Have only tasted it a little here and there. I havent had the time to sit down to enjoy it yet. Because....
The Strawberry I also used UJ (100p). The day I was finishing these up my girlfriend stopped over, so after a 'show and tell' of what I made and 1 pint of SPD over sprite consumed, the qt left with her with the promise to bring the jar back for a refill.
The Pineapple I used my Sweet Feed Mix also 100p and it truned out good. I used fresh pineapple but the syrup stage takes work. I ended up crushing most of pineapple into pulp then adding the sugar. That seems to do well. The flavor turned out better than I expected. I add a little more molasses to my ferment and the flavor carried thru in the drink. Yummy.
So 2 days later my girl showed back up with empty jar in hand. After finishing off my sampler pint of pineapple there went the other qt of pineapple. I think its safe to say she is hooked. And yes the name holds true they did drop each time. Her little joke is "This is the deposit on the jar I'm taking with me when I leave." Hey, who am I to argue?
I currently have 4 qts of both strawberry and pineapple pickeling. I hope they finish before she shows up again.
Now my worry is that she will be stopping by more frequently and I will not have enough time to spend with my still, thus having no more SPD for my girl. Oh what a delima. Maybe I'll just build a bigger still!
When the check out ladies at both Sam's Club and Wall Mart ask "What church are you making fudge for this week?"
I took a short cut. I bought Welch's Strawberry blast and used that with everclear... best stuff ever...
Until...
I bought strawberry daiquiri mix and used that with everclear...THIS is the best I've ever tasted.
Thinking now of fermenting some wine with the daiquiri mix and then fortifying it up to 40 proof... my wine only comes out at 15% or 30 proof... I'll just add enough to make it 20% and it should be even better.
BTW...my spd is only mixed to 40 proof, not 80... it's got to taste good after all.
Until...
OK, so now I cant make the strawberry or pineapple fast enough. Guess it was a hit. However, I am having issues with the blueberry. I bought fresh blueberries and washed them, then froze them. Later added them to 100 proof UJ and let them sit for about a week. It came out with good color and a great blueberry after taste. I have added 2 batches of the syrup but now I am noticing a thin layer of chakie film on the top of the liquid. My first guess was maybe yeast from the berries so i added some 140 proof. The taste is still ok but the film hasn't gone away. Anyone have any Ideas???
Try either using a paper towel to absorb the liquid on the surface and it will pick up the scum at the same time and/or run it through a coffee filter
Ok. I usually run the spd thru a tee shirt then coffee filter when complete and will do the same to this. Is it still safe to drink? What do you think caused it? Tasted it again and notice a bitter after taste now.
Either broken seeds or stems attached would be my best guess10Gallon wrote:Ok. I usually run the spd thru a tee shirt then coffee filter when complete and will do the same to this. Is it still safe to drink? What do you think caused it? Tasted it again and notice a bitter after taste now.
In the filterin process my girlfriend started tastin it. Which really surprised me. She really likes it. Definitely a good idea.
The doctor says i need to drink more whiskey.
Also. I am calling myself "the doctor" now.
" now I am noticing a thin layer of chakie film on the top"
ploom) waxes and yeasts (oleanolic acid) and is naturally produced by the plants. It is antibacterial.???
SPD is great. Yes the droppin properties work. My girlfriend actually wants to help me make it and help run the still.
Caution:
It may not have the leverage it once had if she starts helping you make it, lol
TheOldTimer
Why ya say that buddy?
dont be gettin nekkid while the stills firin, or at least be careful not to back her nekkid butt 'gainst that hot kettle.
That made my night. I love yall. Not in a weird way. Yall are great.
I am confused about how to make it 40 abv if the liquid is thick with syrup won't the hydrometer be incorrect?
yes. best to just estimate based on the volumes and proof of your starting likker. Water it to taste, after all youre making it to satisfy your tastebuds, not an arbitrary number anyway
Im tryin to make some raspberry for my boss. Hopefully itll turn out good.
is your boss female? Are you testing the 'properties' on a new test subject? hahaha
Nah. But he wants to try the properties on his girlfriend. And she like raspberries.
Sounds like you'll be getting a raise soon.
