My first pot still build
Bigmanley2
Post by Bigmanley2 »
It's taken me a month or so to build it to this point my pot is 16 guage stainless and my cap is 16 gauge copper finally got them both welded up today cap won't be permanently connected, and I'm thinking it needs to be a little bigger? Still got to put my cap arm on, I'm going to use 2 in. Copper pipe. And I've still got to put a drain valve on my pot.
Still got to make my thumper and my worm, I'm hoping it does the job the right way I've got a lot of time in this thing
S-Cackalacky
Re: My first pot still build
Post by S-Cackalacky »
Great lookin' start. With your metal workin' skills, I'm lookin' forward to seein' the finished build. Should be somethin' special to behold.
Good luck with it,
S-C
dakotasnake
Post by dakotasnake »
looks good. the cap is big enuff
today marks the dawn of a new error.
just sayin
Post by just sayin »
Very nice stainless and copper! How much is she going to hold?
Bigmanley2
17 gallons to the bottom of the reducer. Think I'm going to make 10 gallon mash. @Dakotasnake I didn't really have anything to go by for my cap size I just used my logic, but it looked small on that pot so I was wondering if it was big enough or needed to be bigger for some reason. Also do y'all know if the 2 inch cap arm is a good size or need to be bigger and does an up or down angle make a difference ? Thanks for the compliments fellas
acfixer69
Post by acfixer69 »
Great looking pot and copper head there. :thumbup:
AC
Bigmanley2
You're right sir it was a typo it's a 17 gallon pot and I was going to run a 10 gallon mash :oops:
Bigmanley2
Oh and I'm building a small stainless gas burner pack to heat it, unless I can find a heating element ALOT cheaper than the ones I've seen so far
acfixer69
Post by acfixer69 »
I use 2 of these http://www.amazon.com/Camco-02963-Screw ... tt+element" onclick="window.open(this.href);return false;" rel="nofollow with a phase angle controller mounted in the boiler with 2 half couplings an run thought controlled thru a phase angle controller. It is the best rig. I run in the basement NO WORRIES.
AC
Run it off my weld socket :thumbup:
Truckinbutch
Post by Truckinbutch »
Build looks fine . 2" will serve you well . I'm partial to gas fired as opposed to electric , just personal preference . Was I you I would build a liebig rather than wrap a worm . Again , personal preference . I feel it is more efficient and can take less space . I favor down angles from the cap to output .
Be safe . Have fun . You've started out real well :clap:
1lowluv
Post by 1lowluv »
Very nice!
Bigmanley2
@acfixer69 I like your idea and I get the concept but I'm not understanding the actual( can't get the picture in my head ) of how to mount it and these controls your talking about, which is why I was going with gas on top of the prices of the elements I've seen for $100+
pfshine
Post by pfshine »
Even if the elements were $100 (i got mine for $20) you would still save money in just a few runs. I figure about one tank of propane or a little less per run at 20 a tank or so vs two or three bucks in electricity. A gain of $17 per run. And its easier to controll and duplicate.
Bigmanley2
Ok, that's absolutely right, and I would like to go with a heating element instead of gas, but I'm not sure about where to put element, where holes shoul go for wire if any holes are needed what kin of controls to put on it to control the element, how do you propose mounting element and control I've never seen a still with hearing element from inside to out maybe one of you guys could make a drawing of how it should go and pm it to me or give a dummies guide explanation. I've always seen gas an or burners like a stove top
Bigmanley2
The beginnings of my thump keg
Halfbaked
Post by Halfbaked »
NICE, VERY NICE. make mine next!
