New distillers reading lounge
A MUST READ FORUM Place where new distillers can read many of the important documents that help introduce them to distilling. This is a read-only forum.
Re: New distillers reading lounge
Postby Bushman » Sat Oct 12, 2013 10:43 am
varocketry wrote:LAMPSHADE:
Any progress yet on the Stalled Fermentations guide you offered to write in August?
I'm experiencing UJSSM stalls and could use some guidance.
Thanks.
It's done just waiting to have it all posted and the Fermentation thread cleaned up a bit. Lampshade did a nice job on that part of it!
Postby lampshade » Sat Oct 12, 2013 12:10 pm
Thanks, Bushman, for your kind words.
varocketry, for my situation, I found the biggest contributor to stalled ferments was pH. As fermentation progresses, the pH naturally lowers and can reach a point where the yeast become unhappy and stall. Baking soda raises the wash pH, is cheap, and does not produce off-flavors. My wash quickly hit the pH danger zone because the water was soft and did not contain the needed buffer minerals. Buffers slow down the pH descent and keep the pH out of the danger zone. Many people also use "5.2 pH Stabilizer", as yeast are most happy at a 5.2 pH.
lampshade
Postby garyerick » Thu Oct 31, 2013 10:43 am
THis is not very helpful at this time.
garyerick
Postby Bushman » Thu Oct 31, 2013 11:50 am
garyerick wrote:THis is not very helpful at this time.
This thread is comments on how to improve the New Distillers Reading Lounge by members, did you actually go to the New Distillers reading lounge? If so what part is not useful to you?
Postby carolina64 » Wed Dec 11, 2013 12:03 pm
Hello, I am Carolina64, I am just in reading stages of making moonshine. I know the oldtimes don't like foolish questions but I have a few simple ones that are not mentioned in any of my reading. We all have to start somewhere right? I am retired and have time to experiment but need to get started off right. I see I need to be invited by group member to join the forum..I would appreciate the help..Does it matter what type water you use..some say distilled, some say can use hot water from the tap because the heat has removed the chemicals in the water, I have seen some videos where they use water straight from the hose. So what is want here?
I know the moonshine does not have to be refrigerated but read that if it is sweeten in any way then it has to be kept in refrigerator. If it is sealed in qt jars will it be fine on the shelf?
I brought some Crossroads All Stock sweetfeed. I was expecting just a mix of crushed grains in the bag, but this has small corn particals stuck to pellets by the sorghoum or molasses in the feed. Do I have the right kind of Sweetfeed??
I hate to ask this one, I don't seek instructions from Moonshiners, but I heard Jim Tom say he uses corn malt to make his mass and not yeast, he says yeast is what gives the headache, with corn malt it will not..Not believing this one unless I can get some feedback from the oldtimers...Hope I don't have to bother you again, maybe next time I can add a new recipe..thanks.
carolina64
Postby evilpea » Wed Dec 11, 2013 12:33 pm
carolina64 wrote:Hello, I am Carolina64, I am just in reading stages of making moonshine. I know the oldtimes don't like foolish questions but I have a few simple ones that are not mentioned in any of my reading. We all have to start somewhere right? I am retired and have time to experiment but need to get started off right. I see I need to be invited by group member to join the forum..I would appreciate the help..Does it matter what type water you use..some say distilled, some say can use hot water from the tap because the heat has removed the chemicals in the water, I have seen some videos where they use water straight from the hose. So what is want here?
Why are you in the recipe section? go to this link viewforum.php?f=27 and post a proper hello.
evilpea
Postby Husker » Wed Dec 11, 2013 12:41 pm
Because this is an announcement thread, so shows up in EVERY forum.
I will see what I can do about that.
Husker
Previous
Return to New distiller reading Lounge
Who is online
Users browsing this forum: No registered users and 0 guests
