start on pot still
start on pot still
So ever since I finished my 3 " boka (that I still haven't been able to run yet because of time constraints) I've been wanting to build something else I've been wanting a simple pot still for doing stripping runs (and the occasional brandy) it also didn't hurt I had a bunch of extra materials laying around so I got started my lyne arm starts out 2" and reduces to 1/2"
Re: start on pot still
So I've been sitters here looking at the above and I was thinking about condensers would it be an option to put back to back 90s at the end of the lyne arm to a liebig or even run the lyne arm horizontal to a 90 to a shotgun condenser
how about a union on the end of it then you can swing the liebig to any position you want
safety and related materials http://homedistiller.org/forum/viewforum.php?f=33
novice guide to cuts http://homedistiller.org/forum/viewtopi ... 15&t=11640
samohans easy pot still http://homedistiller.org/forum/download ... p?id=12153
The reason for the back to back 90s would be to save space
I forgot to mention the liebig would double back underneath the lyne arm
You could do a 90 union 90 Like jholmz said an have great flexibility.
What would the benefits if any of a shotgun condenser be
+3 on the union or clamp, makes life easy handling the still too. A shot guns are good for space saving, they should be vertical for best results but work fine on a angle. Pretty easy to build too.
"Homer J Simpson"
"Homer J Simpson"
