Dan's Flute x2, 4" x 5 plate 42" column
WIski
Re: Dan's Flute x2, 4" x 5 plate 42" column
Post by WIski »
I did notice that the picture of the adapters looked funky when I posted but the one's I got from them where copper with brass nut. They look pretty cool. Further investigation by HD has confirmed Pexsupply has changed their product. I had not found anyone besides Pexsupply that had the copper adapters in 2" only 1.5". I will have to check Lowes. The copper trap adapter with the readily available precut borosilicate glass (Pyrex) is in my opinion a great way to go. Thanks Dan & HD. :thumbup:
dan
Post by dan »
Well Gentlemen it's that time again......
20' of 4" type "L" and 20' of 2" type "K" are now in my shop waiting for a new saw blade so that it can start the process of becoming something useful. 8) My wife said "not until after the holidays" so I agreed.... :ewink: :ewink:
-Dan
time for a new project!
Danespirit
Post by Danespirit »
Oh yeah...a wife can be real persuasive from time to time.. :D
You have done a outstanding job there, Dan.. :thumbup:
Copperjohn
Post by Copperjohn »
Dan, I don't think you listened to your wife. I see you already put an easy flange on one of those pipes.
“A Foolish Faith In Authority Is The Worst Enemy Of The Truth”
Albert Einstein
dan
Post by dan »
CJ-
Just a test fit at the water jet shop..... I had them cut a bunch of parts from 9 square feet of 1/8" copper plate.
-Dan
dan
Post by dan »
I have just started my next project and thought I would add a few pictures of my progress. I don't know if I should start a new build thread or keep this one going for my new version of the same old thing. I might as well keep it here for the people that have been following this and my previous project. I am going to build a few identical columns to see if I can get more efficient at working with copper. This time I purchased every piece of copper at wholesale prices from a plumbing supplier and had my plates and easy flanges cut from 1/8" copper plate at the water-jet place. I am trying to reduce the labor and time it takes to build one. Let the fun begin......
-Dan
humbledore
Post by humbledore »
That is a jaw-dropping amount of beautifully cut copper...this is going to be good.
Copperjohn
Exactly how many is a few? Although you have quite a bit cut, it looks like your still gonna be drilling your plates.
Albert Einstein
dan
Post by dan »
Here are a few more pictures and the sizes that this new project will be. Dephlegmater will be in a 4" x 10" section of the column with seven 1" tubes that are 5_1/4" long. The column body will have five sight glasses and five perforated plates and will be a 4" x 29" Type "L" copper pipe. There will also be a 4" x 24" packed section for producing neutral spirits. Overall the column will be about 63" tall with all sections plus about another three inches for the vapor take--off. The final product condenser will also be a shotgun and will have five 1/2" tubes that are 24" long in a 2" type "K" copper pipe 26" long. The vapor take-off, final product condenser, and product collector will be more modular than my last build so that it can be taken apart and cleaned better. I already know that many of you will frown on the 4" SD "Still Dragon", (shhhh did I say that name out loud??) brass tri-clamp flanges so lets just nip that one in the bud. I will be tinning the 1/2" that is exposed inside the column with solder so that there is no vapor in contact with the 99% lead free brass.
-Dan
Just a few sight glass flanges
Final product collector cup before venting
Dry fit of the dephlegmator
Column sections stacked up for effect
acfixer69
Post by acfixer69 »
What are you putting in the packed section.
AC
dan
Post by dan »
Copperjohn wrote:Exactly how many is a few? Although you have quite a bit cut, it looks like your still gonna be drilling your plates.
CJ- Five to be exact..... 5 x 5 x 180 = 4,500 individual 1/16" holes for the perforated plates and yes they are 1/8" thick. I hope I will still be sane when I am done! :moresarcasm: (pun intended)
-Dan
dan
Post by dan »
acfixer69 wrote:What are you putting in the packed section.
AC
AC-
I will be using lava rock thanks to all of the research done by Mash Rookie.... and many others. I may try other things but that will be the first.
-Dan
Copperjohn
last time you built one for your brother; are you building 5 because you have additional siblings? :ewink:
Albert Einstein
WIski
Post by WIski »
Hi Dan,
Great stuff here as usual. I see your dephleg is 10 inchs long and the inner tubes are 5.25 inchs. I am wondering what the logistics are with that?? Thanks, Great Build!!!!
dan
Post by dan »
-CJ & Ski,
I have many brothers :wink: but I wanted to build a larger quantity to see what my cost average might be and time savings with jigs and mass production. I am not using DWV pipe and fittings to go cheap and make something that just works. I am going with a quality build that you can not buy from any current commercial guys. I think that having the thermal mass of heavy gauge copper helps stabilize the internal temperatures of the column better. What I do know is that I tend to over build just about everything I do. I went with a ten inch dephlegmator body to make extra room for the thermo wells above and below the shotgun and partly because of the SD tri clamp flanges that I am using. The five inch shotgun was a suggestion from OldDog when I first got started. Seems to be all that you need.... Cheers
-Dan
dan
Post by dan »
- A few progress pictures.
-Dan
collector cup attached to final product condenser
collerctor cup gasket
test fit in dephlegmater body
dephlegmater soldered up and cleaned up
dan
Post by dan »
- A few more.....
-Dan
Final product condenser plates
dry fit of final product condenser
bottom end of condenser
top end of condenser
dan
Post by dan »
-Spacing my sight glasses on the column body and showing that even with the SD brass flanges I will still be able to remove my perforated plate tree because the ID of the pipe is smaller than the ID of the flange.
-Dan
SD flange
SD flange
Sight Glass spacing
Sight Glass spacing
Copperjohn
That pretty nice! I had to use one stainless steel flange on the bottom of the column and I made an easy flange on top so I can still pull the tree out the top.
Albert Einstein
Hound Dog
Post by Hound Dog »
Dan, you are one of those artists who work in a copper medium I talk about. Beautiful work!
Using Google Search
dan
Post by dan »
Thank you Hound Dog!
-Dan
dan
Post by dan »
I made a few parts today but still trying to get into a production mode. Trying a few things here and there waiting for a drill bit to show up from ebay so I can drill the sight glass holes in the column body.
-Dan
Column top
Column top
Vapor Take-Off
Vapor Take-Off
Same
Same
Same
Same
Vapor Take-Off on Dephlegmator Body
dan
Post by dan »
The olympic Rings! and a few VTO's..... Got one of them soldered up today and just four more to go tomorrow. Learned how to tin brass today and actually did a decent job by the second or third try.
-Dan
The olympic rings of VTO
Vapor take-off or top of my column
Same
Same
dan
Post by dan »
Forgot how much fun it is to drill 1/8" thick perforated plates! I managed to get one done with one drill bit..... only broke the same one four times, but just made it a bit shorter each time.
-Dan
New Drill Bit
New Drill Bit
New Drill Bit
New Drill Bit
Perf Plate - first of many!
Copperjohn
Have you figured out a price point yet? :?:
Albert Einstein
dan
Post by dan »
Five is a big number.....
Dan
Shotgun Dephlegmater inside parts
emptyglass
Post by emptyglass »
Is that the same hole pattern on the plates you used on your first one Dan?
dan
Post by dan »
-Empty,
The hole pattern is basically same but I did need to move seven holes from around the downcomers because I increased them from 1/2" to 3/4". I kept the plate @ 180 holes that are 0.0625". I will be using your idea of no downcomer cups and just using the downcomer tube cut at a 45 degree angle and 1/2" of opening on the bottom. The top of the downcomer will still be 5/8" above the surface of the perforated plate.
-Dan
dan
Post by dan »
Ten down only fifteen to go....
-Dan
dan
Post by dan »
Perforated Plates
Perforated Plates
Packed Section Plate - Lava rock will fill this section
Made a little progress today but still have five plates left to drill out and then I will be moving on to final product condensers.
-Dan
