Liebig Stands
Zeig
Liebig Stands
Post by Zeig »
A few may have seen me mention im making a new liebig this week but this requires one more thing on my part. my 5 gal pot still can't support a 3-4' condenser. For anyone who has had this issue, what did you support it with? I plan to just connect the still and liebig with copper tubing. i was thinking of using an old tripod attached to the center of the liebig. This way i can control its height and angle. Either way i'm curious what other options have been used.
You can't think of the impossible, because it's impossible. Ergo if you can think it, its possible.
S-Cackalacky
Re: Liebig Stands
Post by S-Cackalacky »
The tripod is a good solution - lets you do fine adjustments for changing the angle. I think I recall seeing at least one other person using a tripod. I really can't think of a better solution.
S-C
Zeig
Re: Liebig Stands
Post by Zeig »
Ah id like to see that. Yea It's the only option i can think of really...
S-Cackalacky
Re: Liebig Stands
Zeig wrote:Ah id like to see that. Yea It's the only option i can think of really...
Try an "HD Google Search" with the search term "tripod". It might turn up something.
S-C
Zeig
Re: Liebig Stands
Post by Zeig »
S-C
You must be some sort of sorcerer ... :D lol brain is a lil fried from studying, thanks
http://homedistiller.org/forum/viewtopi ... d#p7144020
Truckinbutch
Re: Liebig Stands
Post by Truckinbutch »
I used the lower half of an adjustable tripod roller stand from my wood shop . Used a longer section of pipe for height adjustment . Been working great for almost a year .
NineInchNails
Re: Liebig Stands
Post by NineInchNails »
Here's what I initially did to support my liebig:
I found these parts at the local hardware store. I don't recall what they're called. They are copper plated:
Image Image
I drilled a hole in the top rim of my keg to accept an eyelet. I used nuts to secure it to the keg.
I happened to have this aluminum tube which was flattened & forked on both ends. I widened the forks so they fit over a bolt. I used it as the support arm. It came from an old tonneau cover for a pickup bed.
I used a bolt, 2 flat washers and a wing nut like shown below to lock the support arm in place. Easy to loosen, adjust and tighten.
NineInchNails
Re: Liebig Stands
Now a days I just have a small chain hanging from the ceiling and I attach it to the liebig to support it. Just cheapo tiny chain you hang plants with. It's really easy that way and it definitely supports & relieves any stress from all fittings/joints. I don't even use the support rod method anymore.
Some people require a free-standing method so the previous method would work.
S-Cackalacky
Re: Liebig Stands
I've also seen folks design their pot still riser in such a way as to move the center of gravity over the still boiler - a kind of goose neck looking arrangement. There are probably a few examples of the design here on the forum, but I don't have a clue as to how to search for it.
Here's a crude drawing -
S-C
apdb
Location: big ole'island on the West Coast Canada, soon to be underwater when the big one hits
Re: Liebig Stands
Post by apdb »
Anyone tried using a microphone stand?
FreeMountainHermit
Re: Liebig Stands
Post by FreeMountainHermit »
Is the mother-law-law handy ?
FMH.
Blah, blah, blah,........
Coyote
Re: Liebig Stands
Post by Coyote »
Hum
I just hang mine from a light rope
tied to an overhead wire shelf
Coyote
Doogie
Re: Liebig Stands
Post by Doogie »
my dual 2 footer is virtually vertical, and sits in between some 2x4s ... this also allows me to mount the parrot underneath
It is easy enough to build - if you set up on level ground, then I just positioned the vertical liebig higher or lower on the stand.
LTV - "keep in mind distilling is like masturbating. You do one wrong and you go blind."
Want to keep people from consulting idiots on youTube about distilling?? Don't be an idiot when someone asks for advice ... Help them
PsychDoc
Re: Liebig Stands
Post by PsychDoc »
S-Cackalacky wrote:I've also seen folks design their pot still riser in such a way as to move the center of gravity over the still boiler - a kind of goose neck looking arrangement. There are probably a few examples of the design here on the forum, but I don't have a clue as to how to search for it.
The attachment Gooseneck.png is no longer available
S-C
That looks a heck of a lot like mine :thumbup:
1
1
It works really well since all the weight is balanced and straight down! Though this pic doesn't show it I soldered a tab to the top of the 1.5" center piece. Wait...
there you go that one does. And burned the hell out of my fingers doing it. :oops:
It's now on a 7.5 gal keg that I can run full tilt and a trickle of flow through it is plenty to condense everything.
It was a tumultuous time for our nation: the clear beverage craze gave us all a reason to live. The information superhighway showed the average person what some nerd thinks about Star Trek. And the domestication of the dog continued unabated.
