Confused over Liebig length. (Sorry)
Matilda
Post by Matilda »
Hi all,
I'm sorry about this, I know the answers are here, I'm just confused...!!
I'm building a pot still on a 50l keg heated with a 3kw heater with controller.
I planned to have 1metre of 22mm copper around a slightly longer 15mm take off tube. - water in the bottom, out the top, (usual method)
I'm just worried it's not long enough... The calc is pretty confusing :/
Please help :(
Re: Confused over Liebig length. (Sorry)
That size and length is fine!
Matilda
Post by Matilda »
Thanks BM,
Thanks a relief :)
superdaveva
Post by superdaveva »
Make sure you read up on your build,put a wire around it! Read read read
just deal with it bitches
That might not be long enough at it's full 3kw
http://homedistiller.org/calcs/cond_calc
RTClassic
Post by RTClassic »
Put some copper scrubbies in the first few inches of it and it will work fine. I found that unraveling the scrubbies gave me perfect pieces to shove down the liebeg, and they knock down all of the vapors.
PhatFil
Post by PhatFil »
according to the calculator 1m of 15 and 22mm tube is optimum for a running wattage of about 1200W im using a 2.4kw element and a resistance controlled SSR to manage the power, using full pelt to heat up and a lower power to maintain the run.
Truckinbutch
Post by Truckinbutch »
Bottom line is that it is your's and you can play with it however you want to . Run it and observe . Should be fine as you built it . If it starts huffing you are overdriving it or underdriving coolant flow . One hand washes the other . If you don't get the output and speed you expected you can modify . In the meantime ; get good at driving what you got . The experience will stand you in good stead ...................
Halfbaked
Post by Halfbaked »
+1
Truckinbutch wrote:Bottom line is that it is your's and you can play with it however you want to . Run it and observe . Should be fine as you built it . If it starts huffing you are overdriving it or underdriving coolant flow . One hand washes the other . If you don't get the output and speed you expected you can modify . In the meantime ; get good at driving what you got . The experience will stand you in good stead ...................
I'm a shorter than a meter and never had a problem.
The wire or scrubbers to create turbulence is a good idea and what I did on my VM still.
Bagasso
Post by Bagasso »
The calc on the parent site does say that a shorter condensor can be used if the flowrate is increased. A cheap ($10-$15) aquarium water pump can easily provide 4x the 1.23l/m that appears in the flowrate field for 3kw, using a 15mm liebeg.
