Fermenting without bubbler
CBShiner
Post by CBShiner »
I have a mash in a 5 gallon bucket. I took the lid off and the mash (corn) is bubbling away but not forcing gas into the air lock bubbler. I have checked and checked for air leaks and can't find one. Is 10 days long enough? Does it matter that it didn't push the bubbler? Temp, ph, sg are all within range. Can I safely cook it when it stops fermenting? Thanks for any help you can give.
bellybuster
Re: Fermenting without bubbler
Post by bellybuster »
best bet is always checking with hydrometer but if it's done, it's done.
buckets are notorious for air leaks, doesn't take much, no worries as long as you witnessed fermentation. Taste it, should be dry and not sweet.
Jimbo
Post by Jimbo »
them damn lids are worthless. just about all mine leak. whats the gravity? if it stopped dropping and between 0.996 and 1.01 then yes. I dunno your recipe or yeast type so cant tell yuo where it should finish. 10days doesnt mean much without telling us which yeast at what temperature. teh same yeast could take 2 days at 80F and 2 months at 60F
S-Cackalacky
Post by S-Cackalacky »
You didn't say what kind of bucket it is, so I'll assume it's the typical HDPE 5 gallon bucket with a snap on lid. If that's the case, they tend to lose their ability to maintain an airtight sill - especially with repetitive use. The CO2 will take the path of least resistance. It takes a little more force to push the gas through the water in the airlock than it does to push it through a leak in the lid.
That said - you could try putting some weight on the lid to try to force the seal. Also be aware that you don't really need to use an airlock. You could just lay the lid on loosely or put a towel over the bucket to keep insects out. The CO2 being heavier than air will protect the wash from most contamination.
A hydrometer will tell you when the wash has finished fermenting. When it reads 1.0 or lower, it is finished. If you don't have a hydrometer, taste it. It will taste dry - that is, it will have no sweetness.
Posted while Bellybuster and Jimbo were posting.
Painting the seal with simple syrup works for my buckets.
Jimbo
Post by Jimbo »
NZChris wrote:Painting the seal with simple syrup works for my buckets.
and the ants that get lodged in the rims stuck in teh syrup complete the seal? :mrgreen:
Hound Dog
Post by Hound Dog »
Never used an air lock yet. I just ferment in food grade trash cans with a loose snap on lid. Use a hydrometer to tell you when its done not bubbles.
Using Google Search
B_rad1969
Post by B_rad1969 »
I have never had an issue with an air lock. I've never had an issue with my buckets either. I bet you have a crack in the lid.
mmmmmm
Post by mmmmmm »
I never use an airlock on my 5gal bucket, I put the lid on loose, even. I generally do quick ferments. When it's actively fermenting, it's going to produce its own layer of CO2 over the top of it that will keep the air off of it as long as you don't have wind blowing on it or something.
I don't think it would be a problem unless you're pushing a mash for months on end.
No, they don't for some reason. There are plenty of ants around here, I only have to put a bucket that's had messy fruit in it down for a few minutes and they'll be cleaning it up, but they never go storming my syrup seals. Maybe there is too much CO2 in the old fridges I use for incubators.
Old Anarchist
Post by Old Anarchist »
I found that that rather humorous.
honestly i'll probably use a cloth and a string on mine. the lid on my bucket won't seal worth a flip.
Dear lord, please allow this dangerous combination of hair spray, bat slobber, and DOT4 automatic transmission fluid to excite my mind, occupy my spirits, and enrage my body.
Jimbo
Post by Jimbo »
It still seals better than cloth. As long as you arent one of those tgat opens it constantly it will stay full of co2 and be fine. Ever got a snout full of co2? Nothins gonna climb in there. Not even ants :)
Brendan
Post by Brendan »
Haha, there's a new label for you Jimbo...
'Jimbo's Ant Seal Whiskey' (picture of ants stuck in syrup) :lolno:
Maybe replace the tag with a flask/bottle of whiskey :lol:
Or this one
Ok ok, I'm done now :thumbup:
The KYChemist
Post by The KYChemist »
You mean something like this...
Jimbo
Post by Jimbo »
BAHAHAHAA. :clap: :thumbup:
