phase angle controller build
If it plugs in, post it here.
SideJob
Re: phase angle controller build
Post by SideJob »
Thanks will try the above. May have to go back to propane. Just wanted to be fancy and be able to use it inside in the winter.
JDUBYA
Post by JDUBYA »
Is there any way you can post some pics of inside the box. Did you take the power supply out of the case and put the guts of it in your new box. I work better with pics and i can't see from your pics posted.
bellybuster
Post by bellybuster »
sorry about the pics, don't know why I hosted off site.
here's the inside of my box
My fan is run from a 12v wall wort that gets plugged in separately. Just to clean it up some I added a 12v socket to my box for the fan plug in.
