Jar aging
Jar aging
I mentioned this technique I learned at the ADI conference from Black Swan Barrels on my ADI thread but realized it probably would be seen or used more in the proper location so here is a trick for aging in jars on wood. This can be used as your aging processes or to introduce a new flavor note if you first barrel age then want to add a slight flavor change to your whiskey.
If you are aging on wood, they used cherrywood to add a different flavor note. Drill a bunch of holes in the wood like a honeycomb then cut it into jar sizes and put it in your jar. What this does is expose more end grain for absorption and draws the color and flavors of the wood faster. Below is a picture of some aging in a jar, next to the jar on the right is a sample of the wood that has been drilled. You just need to cut it to fit into your jar.
Next picture probably shows the wood better here he used an oak stave.
heartcut
Re: Jar aging
Post by heartcut »
That does look like a honeycomb in the jar, might be a good disguise as well as an aging technique.
heartcut
W. H. Auden
BoisBlancBoy
Re: Jar aging
Post by BoisBlancBoy »
All these aging techniques are killing me! Everything looks so good and I want to go open the few jars image aging for a little sample! I need to stop reading in this sub-forum!
Re: Jar aging
BoisBlancBoy wrote:All these aging techniques are killing me! Everything looks so good and I want to go open the few jars image aging for a little sample! I need to stop reading in this sub-forum!
:lol: :lol: :lol: Believe me it doesn't get any easier!
Re: Jar aging
rockchucker22 wrote:Seems like it would be easy to over oak. Makers Mark 46 uses bags of toasted oak chunks in a stainless aging vat.
I've never over oaked on chips however with this method you are really exposing a lot more end grain and we know how that just wicks water. What I would do is figure the aging time is less than half and be watching the color of the jar, also it's a great excuse to taste on a regular basis. I would suggest using 2 quart mason jars.
heartcut
Re: Jar aging
Post by heartcut »
JD chips, even the big ones, get saturated all the way through, cut a few apart to check. I rechar before aging, then use them in the BBQ afterwards. Bet these sticks would smoke some nice meat in their afterlife.
heartcut
W. H. Auden
Re: Jar aging
heartcut wrote:JD chips, even the big ones, get saturated all the way through, cut a few apart to check. I rechar before aging, then use them in the BBQ afterwards. Bet these sticks would smoke some nice meat in their afterlife.
I was thinking the same thing, mine goes in my smoker!
Bob Loblaw
Re: Jar aging
Post by Bob Loblaw »
Looks interesting Bushman. I'm going to have to try this. Did they toast/char the stave after drilling?
Re: Jar aging
Bob Loblaw wrote:Looks interesting Bushman. I'm going to have to try this. Did they toast/char the stave after drilling?
Didn't look like it but that's probably what I would do!
BDF
Re: Jar aging
Post by BDF »
I thought that people barrel age specifically because the spirit never touches the end-grain and only hits the side grain?
DAD300
Re: Jar aging
Post by DAD300 »
I've heard this fear of end grain stuff for a while now.
Do you think if you cut a piece of wood, there is no end gran all up and down the side of the slab?
You have a good saw and eye if you can do that!
There is always end grain exposed in a barrel.
DSP-AR-20005
Re: Jar aging
Black Swan Barrels have been in business for sometime now so I am guessing they know what they are doing!
DAD300
Re: Jar aging
Post by DAD300 »
I like it Bushman...not only are Black Swan Barrels beautiful, the kerf the stave's so that more end grain is exposed.
DSP-AR-20005
MyUncleMo
Re: Jar aging
Post by MyUncleMo »
The kit that they have for "aging your own" has drilled out dowels that are charred inside and out. This is for a fast oaking I assume.
The ones in the jars at ADI each had their own origin and treatment - and I do not remember seeing fully charred drilled wood soaking in any of the jars.
If all goes as heavily suggested, I will be getting a used Swan from Woodinville Whiskey for Fathers Day. Maybe a nice place to put my rum long term after it ages in new oak for a while?
My Uncke Mo taught me how to make apple Jack when I was in 6th Grade.
Questions? Read this first...
http://ww.homedistiller.org/forum/viewt ... 15&t=52975
Re: Jar aging
MyUncleMo wrote:The kit that they have for "aging your own" has drilled out dowels that are charred inside and out. This is for a fast oaking I assume.
The jars at the top that I took pictures of at ADI had honeycomb inside. Here is a link to their product page showing the honeycomb.
http://www.blackswanbarrels.com/honey-c ... ternative/" onclick="window.open(this.href);return false;" rel="nofollow
MyUncleMo
Re: Jar aging
Post by MyUncleMo »
I'll snap a pic of the kit they gave away at their booth.
Bushman - your photos show what I saw. Drilled yes - but not totally charred like the ones that come with the small bottle, 2 charred drilled dowels and a recipe card for aged cocktails.
peace
Re: Jar aging
MyUncleMo wrote:I'll snap a pic of the kit they gave away at their booth.
peace
Some how I missed the kits they gave away, I also noticed the stuff they had for show was not charred but thought one could if they wanted.
lampshade
Re: Jar aging
Post by lampshade »
Bushman wrote: Some how I missed the kits they gave away, I also noticed the stuff they had for show was not charred but thought one could if they wanted.
How would you char the honeycomb so that the inside walls of the holes are charred? I would presume cook them in the oven.
Or maybe that is not important.
MyUncleMo
Re: Jar aging
Post by MyUncleMo »
Torch?
They came with a 375ml bottle.
MyUncleMo
Re: Jar aging
Post by MyUncleMo »
Here is some single run Hook Rum in a jar with one of these char sticks and a Vanilla Bean, crystallized ginger and a few allspice berries.
The oak stick is due to come out in a day or two or three.
Re: Jar aging
MyUncleMo wrote:Here is some single run Hook Rum in a jar with one of these char sticks and a Vanilla Bean, crystallized ginger and a few allspice berries.
Sounds good, I usually take a small sample to determine time in a bottle!
