is a flange and tri-clamp the only way to go or is there any other option? (i know ill get grilled for this)
looking forward to getting some photos of my work up as it comes together
eck
I know there's hunneds of flange tutorials on here so I don't feel ill be having any problems in that area.MoonWhisky wrote: For the Keg connection look up easy flange in the HD Google search. The 4 gauge copper wire flange is super easy!
googe wrote:Looking forward to seeing your build mate.
im fairly sure the majority of immersion heaters ive been looking at here in the uk are around 3000w so I was thinking id double up. I get that if you want quality you have to pay for it. I am a little short at the moment so cheap will do for a controller in the short term.BigSwede wrote:WooTeck, that controller would work if you limit the size of the element in the boiler... it's only 4,000 watts. Most folk are running 4500 to 5500 watts, or even more. The controller would run VERY hot, and my guess, it'd fail sooner rather than later.
Google search 10,000 watt SCR controller and you'll find others better suited. Generally, - you get what you pay for.
Keep in mind, it's nice to have a little "overhead" in your controller, like a 8,000 watt job powering a 4,000 watt heater.WooTeck wrote:
eck
If your using 2" riser, DON'T DO IT!WooTeck wrote:thanks for the responses guys. really psyched to get this on the go. thinking I might even start up my sacrificial wash and my fist run
that's awesome thanks for the link ill get that ordered in the morning or one very similar to it. yeah i suppose having a bit of leeway is always goodBigSwede wrote: Here's a 9,500 watt job (looks protected with a fuse) for $31 U.S. so about 20 GBP. I'm sure eBay.uk has similar. However you proceed, good luck!
http://www.ebay.com/itm/-/151296988320" onclick="window.open(this.href);return false;" rel="nofollow
i am using 54mm so 2.12" just to be a dick. allot of people have had good results with a flange and clamp. cant find anything on Google for SS Ferrell. wondering how hard or if it would be possible to join with a coupler.ShineonCrazyDiamond wrote: If your using 2" riser, DON'T DO IT!
Sorry Moon whiskey, but I did both. Definitely go with a SS Ferrell. I so wanted my easy flange to work, I really did. Spent a week or 2 on it. Finally bought a Ferrell, and was done in 5 minutes.
so your saying this what i should be looking for?ShineonCrazyDiamond wrote:Auto correct...
http://www.amazon.com/gp/product/B00835 ... UTF8&psc=1" onclick="window.open(this.href);return false;" rel="nofollow
It was under 10 when I ordered it...
Awesome. That just means you deserve to win. Keep going. Good luck! And remember, it's worth it!WooTeck wrote:My friend I am going to attempt to do it myself but if I fail I have a ferrule on it's way just incase.
Try, try, try again. Then give up and go with the easy option.
yeh there defiantly is a lining of some kindBigSwede wrote:With no one able to inspect the barrel, you're a bit on your own there, I'm afraid.
You should be able to detect any sort of lining.
