Bubble Bowl Column Build (BBC)
MoonWhisky
Post by MoonWhisky »
On this thread I will be posting pics of my Bubble Bowl Column Build. I absolutely love the idea of having a plated column and most importantly I want to see them in action! So what my build will consist of are 4 bubble bowls with bubble cap plates in each bowl. The first plate will have a 6" copper disc with 12 bubble caps. The other three I'm not sure yet but they will be similar. I will have a small dephlagmetor on it to flood the the plates and a shotgun condenser following that. The good thing about this build is I will be able to add or remove the amount of bubble bowls in a row. They will bolt together or possibly tri-clover assembly. The bowls only cost $1.97 a piece which is a heck of a lot cheaper than 4"-7" copper pipe.. I'm open to ideas & thoughts so let get going!
MoonWhisky
Re: Bubble Bowl Column Build (BBC)
Made the first hole in a bowl
Silver brazed the 2" ferrule on. Wasn't as bad as I thought
Will fit nicely
Will fit nicely
I just stacked them up as I wanted to see how it looks
Next to install sight glass assembly
More to follow as I'm waiting on more parts to arrive. :roll:
Halfbaked
Post by Halfbaked »
Do you ever sleep? Wow! Here we go again. I think I am gonna like this one also. I am assuming that you will put ferrules on top and bottom of bowls? Will you be to posting prices and where you got your stuff and sizes so I can run out and get your salad bowl Moon Whiskey style. That would be amazing if you could find salad bowls that you could actually use triclamps on and an everlasting gasket.
MoonWhisky
The outter rim of the bowls are 7-7/8 just under 8 inches and a 8" tri-clamp cost $36.00 and I haven't found a 7" tri-clamp yet. The cheaper alternative will be 8 stainless steel bolts around the rim to hold them together with a gasket in between. I can get all my nuts and bolts for the price of just half a one 8" tri-clamp so that will most likely be the way I go. Plus I don't even know If a 8" tri-clamp would work as there isn't enough lip on the bowls to squeeze them together.
MoonWhisky
halfbaked wrote:Do you ever sleep? Wow! Here we go again. I think I am gonna like this one also. I am assuming that you will put ferrules on top and bottom of bowls?.
Not sure. That will get costly and will be very extensive with brazing as the bowls are only .012" thick on bottom. What I'm going to is braze the bowls together then cut out a 3" diameter hole the way the vapors won't get bottle necked, we'll see though
InglisHill
Post by InglisHill »
Wicked cool,
I am excited about this one!
I really like all that shiny stainless!
Silver soldering stainless to copper, I think you will find it pretty easy mate if you past build is anything to make such a judgement upon!
Halfbaked
Post by Halfbaked »
I like that even better. You are gonna save some money and some work by brazing/soldering the bowls together. :clap:
thatguy1313
Post by thatguy1313 »
Damn! Every time I look at your builds I get a new idea! Always good to get the creative juices flowing! I'm starting to run out of money though!
No, officer, I wasn't distilling alcohol! It was probably that guy!
Important information for new distillers
MoonWhisky
My simple sight glass assembly
2" ferrule,  2" o-ring, 2" sight glass,  2" tri-clamp
I wrapped teflon tape around the glass to cushion clamp pressure
Assembled
Assembled
InglisHill
mint, where did you get your sight glasses? I am after some 4" ones, over here in NZ.
I was quoted far too much by a glass blower.
MoonWhisky
Still Dragon sells 2", 3", and I believe 4"
Brutal
Post by Brutal »
Me and you think a lot alike brother.
MoonWhisky
Brutal wrote:Me and you think a lot alike brother.
What's your plan?
Brutal
Post by Brutal »
The plan was to hopefully get huge triclamp ferrules and a huge clamp to put the two bowls together. Then a 2" on bottom to attach to a keg, and another on top for a pot still head. Probably another one for a window. Just a big bubble plate under a pot head. Gonna take some fancy ss welding. One too many projects for me right now.
MoonWhisky
More progress
Template for drilling holes
Brazed the bowls together
All the sections
All the sections
Bolted together
Bolted together
24" tall
24" tall
jarheadshiner
Post by jarheadshiner »
Pretty sweet man!
Are you gonna "sandwich" the plates between the bowls or solder them in place in the bottom bowl half?
Lead, follow, or get the **** out of the way!
MoonWhisky
The plates will just rest in the bottom bowl
MoonWhisky
Brutal wrote:The plan was to hopefully get huge triclamp ferrules and a huge clamp to put the two bowls together. Then a 2" on bottom to attach to a keg, and another on top for a pot still head. Probably another one for a window. Just a big bubble plate under a pot head. Gonna take some fancy ss welding. One too many projects for me right now.
Need to find bowls with lips that way you can bolt them together.
bellybuster
Post by bellybuster »
That's wicked, I'd be tempted to run it straight thru as a pot still to see the outcome compared to a straight 2" pipe
Halfbaked
Post by Halfbaked »
bellybuster wrote:That's wicked, I'd be tempted to run it straight thru as a pot still to see the outcome compared to a straight 2" pipe
Most def have to give that a try. Moonwhiskey where did you get your bowls and what they cost you?
MoonWhisky
Here's the link for the bowls - - - > http://www.webstaurantstore.com/1-1-2-q ... MXB15.html" onclick="window.open(this.href);return false;" rel="nofollow
MoonWhisky
bellybuster wrote:That's wicked, I'd be tempted to run it straight thru as a pot still to ser the outcome compared to a straight 2" pipe
The bowl column will have a 2" neck then open up to 7.5" at the widest point. Where the bowls are brazed together is 3.5" so I will be cutting a 3" hole in the bowls for the vapor path. Then it will be back to the 2" for condensing. Not sure yet how I want to condense the vapor. I want a shotgun condenser but not sure where to place it.
googe
Post by googe »
No stopping you is there :lol: , looks cool :thumbup: . Reminds me of maximus's cooling tower thingy!. What did you use t I Brazil the bowls together?. My first plated column was like that sort of, pain in the ads to build, yours will be much easier!. Good luck mate.
"Homer J Simpson"
MoonWhisky
googe wrote:What did you use t I Brazil the bowls together?. My first plated column was like that sort of, pain in the ads to build, yours will be much easier!. Good luck mate.
I used
and silver solder.
MoonWhisky
I started on one of the plates today.
6" copper disc
6" copper disc
Template for drilling holes. The inner circles are 1/2 pipe and outter are 3/4 end caps. I will have 15 bubble caps & 1 drain on the plate
Marking the centers
Marking the centers
1/2" (.625) holes are drilled. Started with a small bit and worked my way up.
I ran out of 3/4 end caps. I bought all the store had do waiting on inventory.
Think there spaced out enough. This is all new to me as i never made anything like is.
Halfbaked
Post by Halfbaked »
:clap: I'd love to see a little more detail on the bubble caps.
MoonWhisky
Yeah they're not done yet, I believe what I'm going to is solder 1/2 pipe in the plate holes and let them stick up 1/2-5/8 then just let the 3/4 caps rest over the top put I will connect them all together by soldering 6 gauge copper wire over the tops so they don't move but I will be able to remove them for cleaning.
I've never made bubble caps and really have no idea what I'm doing. I'm just taking what I think should work in my head and bringing it to life haha.
MoonWhisky
Getting high tech
Using the EDM to cut the 3.25" diameter hole in the bowls
MoonWhisky
Holes are made I ended up making them larger to 3.5 diameter. So my perfect circles got ruin as I just used a grinding wheel to make them bigger
Got my brazed joints cleaned up
Starting to become something
skow69
Post by skow69 »
I love the look. It's like flying saucers having an orgy. Kinky basterds!
