First thumper
First thumper
My newest, beatest thumper all SS and copper pipe. The rest is moving along pretty good should get to welding on it tomorrow. I'll put up more pictures ASAP
Re: First thumper
Nice one BigM.
What is it made from? I mean did you form the whole thing or was it a pre made stainless vessel?
Re: First thumper
No sir I had pieces laser cut and I rolled them and welded it all up. It's 18gauge SS and the 1 inch tubes are copper witch I welded in also
Re: First thumper
Tat is a real nice job you did there, did you purge weld it?
Re: First thumper
Yessir it's as clean as they come
Re: First thumper
What did you use as filler for the Cu to SS welds?
I know it is tricky, well done you!
- Truckinbutch
Re: First thumper
Move your seat to the front of the class , sir . You have learned well
