Molasses Rum wash ABV
Anything to do with rum
pochine
Post by pochine »
I know that a molasses wash has a lot of unfermentables thus not giving a correct sg reading relating to the ABV.
So how can I measure my ABV of my fermented wash?
Tokoroa_Shiner
Re: Molasses Rum wash ABV
Post by Tokoroa_Shiner »
SG - FG. The I fermentables that throw off your reading at the start will still be there to throw it off in the same way at the end. You probably won't be able to get an exact number. But it will be close enough
The Rules By Which We Live By
Safety And Related Issues
New Distillers Reading Lounge
bearriver
Post by bearriver »
Easy, calculate the fermentable sugars in the molasses. It should say right on the label.
Once you know how much sugar is in you molasses, there are calculators on the parent site to figure the SG.
rager
Post by rager »
Tokoroa_Shiner wrote:SG - FG. The I fermentables that throw off your reading at the start will still be there to throw it off in the same way at the end. You probably won't be able to get an exact number. But it will be close enough
this~^
my recipe is half sugar and half molasses . I can usually get to 1.010 and under in less than 5 days. if I let it finish out for a few more days it will finish and clear to 1.00ish . my sg is 1.07/8 or so doing 5 gallon batches
pochine
Post by pochine »
Bearriver - it doesn't state the fermentable sugars on the label. I have seen somewhere on here how much fermentable sugar molasses has.
Rager - I will use the same recipe. Molasses and sugar.
So if I start with 1.094 and finish with 1.014 that makes it 0.080 (SG -FG)
How does that relate to my finished wash?
skow69
Post by skow69 »
ABV = (SG-FG)*129
Your wash is about 10.3% alcohol.
I use the % scale on the hydrometer.
pochine
Post by pochine »
skow69 wrote:ABV = (SG-FG)*129
how did you get that?
skow69
Post by skow69 »
From the 1st law of alcodynamics:
P = /\g*0
Purity (ABV) = delta g (change in gravity) x 0 (theta, the coefficient of fermentation, 129.42671)
P = (1.094 - 1.014)*129
P = 0.080*129
P = 10.32% ABV
Skol,
skow
