I like building things, so I thought I would experiment. I started with the reflux condenser. I used a 1 1/2" copper pipe, 14" long as the base. I attached this to a 2" adapter to fit the top of my column. I also ground off the nibs on the adapter so I could push it through and get more centralized drips back on to the packing.
The way the cooling works is twofold. The air enters in from the top of the ABS enclosure and cools the column. It then exits the enclosure through 1/2" copper pipes running through the column and out through the side of the ABS enclosure. This method affords a lot more surface area for the vapor to come in contact with.
Here's a picture of the column with the pipes running through it:
Here is a picture of the final assembly:
The blower should arrive in the next couple of days. I also have to make an adapter to fit the blower with a tube to feed this thing. Still a work in progress, so I'll update the thread as I go along.
Hell, it may even work....
