still_stirrin wrote:Good summary BB.
I usually start wide open for heat up too. Periodically, I feel the column riser and the top of the shotgun to monitor how close I am getting to boiling. As it gets too hot to touch, I know that the boil is imminent.
I then slowly start reducing the heat as I get to the foreshots. If I'm doing a reflux run, I slow down to roughly 10 to 12 amps (120V) and let the reflux stabilize for 20-30 minutes. If running the strip/pot still, I set it at a power input that produces a pencil thick stream (12 to 14 amps, usually).
If I need to stop the boil, turning the power down will almost immediately stop the boil. It doesn't change the wash temperature though, just curtail the boil.
The electric control gives a great control of the boil. I think you'll very quickly come to appreciate the switch over to electricity (from propane).
Also, I believe that internal heating elements are much more responsive than external heating elements, like stovetop or hotplate elements.
Definately loving the electric now that I've figured it out. I still don't have my volt meter for it, so I've wired up a connector that I can plug my multimeter into to monitor the voltage. I fire it up to where I hear the element sizzle, and then back it off a tad, as the wash heats up I give it a little more till I'm at full power. (I just don't like the full bore sizzle sounds even though I know it's fine)
Once I start drawing product, I adjust my stream, and then disconnect my leads on my multimeter from the power controller, and connect to my vapour temp sensor. I watch the temps just as an information thing, and I'm actually learning a lot from it, never had a visual temp before, so it's something new for me.
I also have a temp gauge in the wash, so I get a nice visual of the difference between the wash temp and vapours temps. I've also started logging the temp changes and how my abv changes along with it.
Now to get the water and power into my still room so I don't have to sit in front of the washing machine lol.
