Absolutely. It would make sense that new stills would be used for the testing, or at minimum, heavily cleaned stills. Most likely to ensure some sense of control, I.e. No foreign contaminants to skew the results.corene1 wrote:Well I have been gone for a few days and am trying to catch up on what is going on, quite a bit apparently. So first off I am not a scientist, I am a welder fabricator and have no scientific information to offer but I do have a thought on this that could be thought provoking in the testing's mentioned. This is just an opinion though. Are these tests on copper done with virgin copper or seasoned copper. All I know Is that after my cleaning runs and the sacrificial runs my spirits only got better and better as the patina developed inside the copper. Could this Patina actually be a seal between the hot alcohol vapors and the virgin copper keeping leaching to a minimum? I think of this when I see the big copper potstills in Scotland and Ireland that are a hundred plus years old and have not shown signs of erosion . I know they don't run 24/7 so they must also be exposed to oxygen at some time. Then multiply that over their life span. Just a thought.
If you look at the pics of the pipe cross sections I posted, you'll see the green in the pipe where it's not eroded. That's the same patina that is developed in our stills (with a few minerals from the water as well). it also slows your house water from leeching as much copper into your drinking water as well.
New homes have higher copper leeching than older homes. The petina in household piping is constantly changing. turbulence in the water wears it down, redisolves it, and it redevelops. In our stills, if we leave it be, (don't scrub it out) it is allowed allowed to remain and do its job.
Edit: another note about household piping, back in the day, piping was simple, straight runs, all the same size, from the meter to all the fixtures was pretty much the same. Keeping pressure and velocity constant thoughout the system.
These days we have 1" pipe coming into the home, reducing to 3/4" and then to 1/2" everywhere. With every decrease in size, pressure is reduced, and velocity is increased. With sudden increases in velocity, you get extra turbulence, which speeds the erosion problems and slower petina buildup.
