its going to foam
blueduck
its going to foam
Post by blueduck »
I'm about to run my first AG and I know it will foam up it finished at 1.000. so any way what do you guys think will work the best to stop it from foaming.
I have see that butter, olive oil, vegetable all work for this . does any one have a opinion on what works the best or does it not matter.
The fun is in the outcome
Bigbob
Re: its going to foam
Post by Bigbob »
I think any of those would work the same, but I have no experience with them. I've also read here that you could get by with not filling the boiler all the way and lower your start up heat. Good luck!
midlife-u-turn
Post by midlife-u-turn »
I fill my boiler to about the same capacity with all grains as the sugar heads and give it a good shot of the non-stick spray in a can. It has the oil to film the surface and most of them also list an anti-foaming agent on the label. All I know is when I started using it I haven't had a foam up issue. It takes very little and stays on the surface so you can use the dunder or backset for subsequent batches without taking any of it off the top.
Last edited by midlife-u-turn on Sun Jun 28, 2015 4:32 pm, edited 1 time in total.
Truckinbutch
Post by Truckinbutch »
Wish I could hep ya . Built my rig with all these considerations in mind and thereby missed most of them .
One Sock
Post by One Sock »
I always put a sliver of butter in the boiler, even if foaming wouldn't have been an issue I can can tell people "Do ya notice that buttery feel? I distill it with butter!" Total bull probably that it adds any to the flavor, but everybody swears they can taste it! :lol:
Boda Getta
Post by Boda Getta »
I just ran a rye single malt the other day with zero problems. I used some anti-forming agent I got from Mile Hi but also filled my boiler only half full and brought it up to heat very slowly. I'm not sure if these precautions alone would have prevented foaming without the anti-foaming stuff. I ran a barley single malt also and took no extra precautions and had no problems, but have read enough on rye mash foarming that I wanted to avoid problems.
Good luck
BG
blueduck
Post by blueduck »
well I put 6 .5 gal in a 8.9 gal pot with a shot of pam (aka cooking spray) and ran it like I would for ujssm no foam thx for the tips guys :clap:
humbledore
Post by humbledore »
Glad it went well. Fermcap S can be found at any brew store, cheap and works great also.
