going electric
Shine NOLA
going electric
Post by Shine NOLA »
Well I've been running on propane for the last year and it has been fun learning.
I'm tired of the noise and heat so wanting to try changing up to electric.
I was wondering if someone could give a little advice and tell me if this voltage regulator will work
http://www.ebay.com/itm/AC110V-220V-75A ... 20fcc14c0b" onclick="window.open(this.href);return false;" rel="nofollow
thanks for all the help
for everything bad, whiskey; for everything good, the same
S-Cackalacky
Re: going electric
Post by S-Cackalacky »
That's the one a lot of folks here are now using. You'll want to put it in an enclosure (for safety). There is at least one thread here somewhere that will give you a lot more detail about it - that is, how to set it up. Good luck with it.
greggn
Re: going electric
Post by greggn »
Is there anything actually mounted to that large heatsink ? It appears to just be sitting loose in the chassis.
FWIW, this makes a very simple and stable controller ...
http://www.auberins.com/index.php?main_ ... cts_id=332
________________
Shine NOLA
Re: going electric
S-Cackalacky wrote:That's the one a lot of folks here are now using. You'll want to put it in an enclosure (for safety). There is at least one thread here somewhere that will give you a lot more detail about it - that is, how to set it up. Good luck with it.
thanks S-Cackalacky for the quick response .
just wanted to make sure before placing my order.
you're a big help
S-Cackalacky
Re: going electric
greggn wrote:Is there anything actually mounted to that large heatsink ? It appears to just be sitting loose in the chassis.
The SCR is attached to the heatsink. The wiring obscures it in most of the photos. There's one photo that shows it if you zoom it in.
likker liker
Re: going electric
Post by likker liker »
http://homedistiller.org/forum/viewtopi ... 7231415did you look at other peoples controllers
http://homedistiller.org/forum/viewtopi ... d#p7323787
There is a few different ways to go, do your research first
Danespirit
Re: going electric
Post by Danespirit »
I am currently using the little brother to this one, a 3,8 KW SCR.
Never had any problems, but i will admit the heatsink could have been a little larger.
This is not a issue , but will be fixed when i make my new controllerbox (when i got the time to do it).
BentJar
Re: going electric
Post by BentJar »
Shine, that one works well and is easier to fab up due to the enclosed fan already there.
Going electric is the best way to go and you will be very happy you worked it out.
OLD MAN IN THE SHED
Antler24
Re: going electric
Post by Antler24 »
BentJar wrote:Shine, that one works well and is easier to fab up due to the enclosed fan already there.
+1 I have the same unit, works like a charm. I snagged a power cord from an old dryer, got this controller for like $25 shipped, and $40 for a 5500w ULWD element and weld spud. So for less than $70 I was able to move my setup indoors, awesome!
Swedish Pride wrote:
Shine NOLA
Re: going electric
thanks for all the help gentlemen .
I look forward to running "silent"
Antler24
Re: going electric
Post by Antler24 »
Shine NOLA wrote:thanks for all the help gentlemen .
It ain't exactly silent but it's very quiet. The higher power input the more you hear it. It's nothing compared to propane. It's similar to the sound of a tea kettle coming to a boil.
Re: going electric
The sounds I hear are from the water flowing through the condensers. That, and noise of the fan blowing over the heatsink to which my triacs are mounted.
The boiler is insulated, so the sound of the wash boiling is unnoticeable. Ditto for the column.
All in all, it's a lot quieter than a propane jet or banjo.
Snackson
Re: going electric
Post by Snackson »
Electric is great and let's you stay indoors if you want. I built a controller for my buddy using that same thing, just bought it off Amazon and he loves it!
bellybuster
Re: going electric
Post by bellybuster »
If I did it again Id buy this to go with my SSR
http://www.auberins.com/index.php?main_ ... cts_id=444
Shine NOLA
Re: going electric
bellybuster wrote:If I did it again Id buy this to go with my SSR
That sure is sweet. Working on my pot still now
I'll keep it in mind when I start work on my other keg for reflux still
Shine NOLA
Re: going electric
Then again I don't think this will work due to low output as per specs.
Amps output are way to low for our needs
Specification
Power input: 90-260VAC, 50 Hz or 60 Hz.
Control resolution: 1%.
Control mode: burst firing mode* (default), time proportional mode**. (See Note1 below)
Output: 12VDC, 80 mA. (can drive up to 6 SSRs in parallel)
bellybuster
Re: going electric
it only needs to power an SSR, out put is fine
