Glass Marbles for Reflux Column Structured Packing
Re: Glass Marbles for Reflux Column Structured Packing
I will be watching this one as well. Be great to see a direct comparison to lava. A video would be awesome and it sure does
look badass.
look badass.
- Kegg_jam
That thing must weigh a ton.
+1 on weighing a ton. It is bad ass! Should be easy to clean up too. How much do you pay for marbles? I see them on line at Moon Marbles for $32/6lbs. That's around $160 + shipping. Interested to see how they work.Kegg_jam wrote:That thing must weigh a ton.
Using Google Search
Using Google Search
It's actually not a whole lot heavier than the lava rock, which is surprising. I think with shipping, the marbles were about $120 or so.Hound Dog wrote:+1 on weighing a ton. It is bad ass! Should be easy to clean up too. How much do you pay for marbles? I see them on line at Moon Marbles for $32/6lbs. That's around $160 + shipping. Interested to see how they work.Kegg_jam wrote:That thing must weigh a ton.
stillin' when I shoulda been buyin'
Not bad! Can't wait to see how it performs.700G wrote:It's actually not a whole lot heavier than the lava rock, which is surprising. I think with shipping, the marbles were about $120 or so.Hound Dog wrote:+1 on weighing a ton. It is bad ass! Should be easy to clean up too. How much do you pay for marbles? I see them on line at Moon Marbles for $32/6lbs. That's around $160 + shipping. Interested to see how they work.Kegg_jam wrote:That thing must weigh a ton.
Using Google Search
Using Google Search
700G wrote:...It's actually not a whole lot heavier than the lava rock, which is surprising. I think with shipping, the marbles were about $120 or so....
I paid $3 USD for 2 lb. here: http://www.hobbylobby.com/Floral-%26-We ... les/p/3504" onclick="window.open(this.href);return false;" rel="nofollow
I bought 2 bags for a 2" x 39" copper column...more than I needed. One bag just about filled it. You must have more $$$ than me.
Went to fire up the test last Wednesday, but my controller took a dump. Back in action today! So far so good. First jar is running 96.4, at the same speed as lava:
I wish there was a way to post videos anonymously, cause I definitely want to! I take a lot of videos with the Pyrex column.still_stirrin wrote:I'm watchin' ya', 700G.
So, when you run it, could you take a video and post it? I'm terribly curious what the column insides looks like when running.
On jar #18 now, the cooling water temp has raised just a bit allowing a slightly faster output and the ABV is running higher at 97.1. Yes, I'm using a temp corrected ABV. Weird!
700g - what kind of wattage/amperage + boiler size + %wash are you running out of curiosity?
I have a 4" column and I was not happy with the copper packing situation... wondering if this might be a help
Running a wash that is 15 gallons and approximately 30% in a 25 gallon boiler around 17 amps powering a 5500W element.LBHD wrote:700g - what kind of wattage/amperage + boiler size + %wash are you running out of curiosity?
700G wrote:Running a wash that is 15 gallons and approximately 30% in a 25 gallon boiler around 17 amps powering a 5500W element.LBHD wrote:700g - what kind of wattage/amperage + boiler size + %wash are you running out of curiosity?
Thanks!
Me thinks your alcoholometer is out. Lol. Have you checked it in water?700G wrote:On jar #18 now, the cooling water temp has raised just a bit allowing a slightly faster output and the ABV is running higher at 97.1. Yes, I'm using a temp corrected ABV. Weird!
Nope, it's dead on.Monkeyman88 wrote:Me thinks your alcoholometer is out. Lol. Have you checked it in water?700G wrote:On jar #18 now, the cooling water temp has raised just a bit allowing a slightly faster output and the ABV is running higher at 97.1. Yes, I'm using a temp corrected ABV. Weird!
Great to hear your success!700G wrote:Went to fire up the test last Wednesday, but my controller took a dump. Back in action today! So far so good. First jar is running 96.4, at the same speed as lava:
Using Google Search
Using Google Search
Run number three with the marbles is underway right now. I'm running a little faster at azeotrope than with lava and cleaning is way easier. I think I'm gonna stick with marbles for a while
- Brutal
Who would have thought it was possible. On paper it doesn't make sense. Thank you for posting your observations with marbles.700G wrote:Run number three with the marbles is underway right now. I'm running a little faster at azeotrope than with lava and cleaning is way easier. I think I'm gonna stick with marbles for a while
700g - sorry for the repeated q's-
how tall is your marble column?
No worries, always glad to help. It's a 48" column with about 45" of marbles. Just now finished another run.LBHD wrote:700g - sorry for the repeated q's-
- FuelMaker
Sorry to keep peppering you with questions 700..
Did you etch or roughen your marbles in any way? I have to wonder how roughened marbles would compare to etched SPP in a head-to-head comparison.
"A little bit of oops goes a long way."
No, smooth right out of the bag.FuelMaker wrote:Sorry to keep peppering you with questions 700..
Marbles are THE most efficient column packing depending on how you measure efficiency.
I measure efficiency by using a controlled wattage, controlled alcohol content in the beer, given length of column, running it at 95 percent and minimizing reflux to maximize product pull.
If you run a column "too tall" it does not hurt efficiency. If you run it too "short", you have to increase reflux to maintain 95 percent.
With marbles you can run the shortest column and still get the maximum speed.
I tried rocks, marbles, lava, rings, 7 types of mesh in 1.5, 2.0, 2.5, 3.0 inch diameter columns.
Marbles are the most CONSISTENT packing material. No stovepiping, each level is GUARANTEED consistent.
Chaos theory at its finest.
- BoisBlancBoy
Anyone know how to figure how many marbles, in weight I would need for 3"x48" column?
from the guy above, 2 inch by 44 is 6.75 pounds.BoisBlancBoy wrote:Anyone know how to figure how many marbles, in weight I would need for 3"x48" column?
pi r squared, says 3.14 square inches, by 44 is 138 cubic inches.
6.75/138 is .049 lbs/cubic inch
1.5*1.5*3.14*48 is 339 *.049 =
16 pounds.
fwiw, 48 inch is pretty silly long for a 2 inch column with marbles. 32 is probably enough, and 36 gives margin. longer doesn't hurt anything though, or so she says.
Should be about a 2000 watt boiler????
That sounds a little under to me. my 48"x2" column took pretty much 8.5 lbs. The size of the marble will make a difference. Mine were 5/8" marbles from DollarTree
I figgure It should be 19.2 lbs (that could be different depending on how the marbles stack in a 3 inch tube vs a 2 inch tube.
- BoisBlancBoy
Thanks Drmiller! Could you explain this further? If I've got the length why not fill it?drmiller100 wrote:fwiw, 48 inch is pretty silly long for a 2 inch column with marbles. 32 is probably enough, and 36 gives margin. longer doesn't hurt anything though, or so she says.BoisBlancBoy wrote:Anyone know how to figure how many marbles, in weight I would need for 3"x48" column?
Also I have either a 7 or 15 keg boiler on a propane burner, no idea of the btu rating.
yeah, no reason not to fill it. but if say marbles came in 5 pound increments, 15 pounds would be "enough."BoisBlancBoy wrote:[
so this is kind of iffy, but I always thought the column would fluid fill first at the bottom of the marbles when you ran it too hard.
So, I got in the habit of making a "basket" for the bottom - like a rounded bowl of mesh. seemed to help, but it may have been my imagination.
The sack of marbles from Hobby Lobby has a tag on them that saysstill_stirrin wrote:700G wrote:...It's actually not a whole lot heavier than the lava rock, which is surprising. I think with shipping, the marbles were about $120 or so....![]()
"Decorative use only - Not a toy. Not intended for Children or Food use. This item May Contain a Water Soluble Surface Coating"
What is the coating and is it toxic? The marbles feel waxy
put some water in your still with the marbles in. run it up to temp with no cooling water so steam comes out the top. let it cool off and throw away the water.shadylane wrote:The sack of marbles from Hobby Lobby has a tag on them that saysstill_stirrin wrote:700G wrote:...It's actually not a whole lot heavier than the lava rock, which is surprising. I think with shipping, the marbles were about $120 or so....![]()
