hoochlover wrote:Are you aware of any research which has been done on adding bentonite *AFTER* the stripping run to help reduce tails? I suspect adding bentonite at this stage would help soak up some tails but have never tried it myself. I may split the 10L into a 5/5 batch and use bentonite on one.
Looong time ago I had some feints and added active carbon (pellets powder) and it did not settle after two weeks (today I think there was a problem with the carbon, but I'm not sure). For fun I tried Turboclear (first silica sol, then chitosan) and it worked for the one bottle, for the other not... After removing the most of the carbon from the bottom of the bottle, I added sodium carbonate in the greyish feints and Surprise! this removed the carbon dust, it settled.
What I want to say is, try it.
But we have one tool to reduce tails in low wines: active carbon. Did you ever try? If not, you don't have a comparision, if you have success with bentonite. I also tried bentonite-gelatine-silica sol. It was not better than without bentonite.
Btw did you try the other clearing agents for a wash? The fast and effective silica sol and gelatine clearing? In my experience more effective then bentonite.
Do you know the theory about clearing agents (the polarity and so on...)? Sorry I don't remember everything of your posts, probably you know that all.
For me up to now the fastes way for the most neutral neutral is:
-Fast fermentation speed (much yeast, not too low temperature)
-Clearing agents (silica sol and gelatine/chitosan). It needs 36h.
-Fast stripping
-Active carbon powder 10g/l low wines. Settling out needs a few days. Perhaps you could cut this step.
-Sodium carbonate 5g/l
-Spirit run
-Active carbon pipe
This will taste absolutely neutral but boring. I use such alcohol for vapor infused spirits or mazerations, but not for a vodka. For a vodka I would cut at least the carbon pipe.
