Modified an old coffee can by tack welding on a length of Perforated Pipe Hanger Strapping ... without it the coffee can would "walk" around in the pot when the product was boiling, also that bit of distance REALLY reduces the coffee can's temperature as it's not picking up much heat directly from the pots bottom ... the Pyrex dish goes in the bottom of the coffee can as an insulator ... keeps the finished distillate much cooler
The is what it looks assembled before the Wok is in place!
A few tricks I learned ... run it HOT 180 to 190 F ... I get 1 litre of 112 proof out ... from 4 litres of sugar wash turbo yeast 19% in ... and it's clear as glass!
Sugar wash has no wood alcohol (well less than fresh apple juice) so there's no need to try and save out tails or heads, Don't open it till you're ready to bottle.
The turkey thermometer is calibrated (has a really long tail) and measures the wash temperature through a small hole drilled near the pots handle.
55 minutes (starting when the temp reaches 150F) is plenty long enough.
Keep the Wok full of ice ... the weight helps seal it on the pot!
Anyone who says it tastes awful? ... has probably actually tried some ... it's not very good!
It's cheap! A 26'er for $3? ... cannot complain about the cost (a 26'r costs $25+ up here)
It's FAST ... Sugar, Turbo Yeast, Water, 5 days ... 55 minutes to distill per litre
