still build
googe
Re: still build
Can you give us a better description of the smell?, lots of things smell bad. What did you the for the sac run?.
"Homer J Simpson"
"Homer J Simpson"
- WooTeck
Re: still build
A stomach wrenching chemically nastiness. All together very unpleasant and im unwilling to put a sipping wash trough in case it picks up bad flavours. Ill give a better description if needed when im home and able to sniff it
i used a fruit cider that i didn’t fancy drinking.
- SoMo
Re: still build
Throw a cheap wash together high gravity against most advice for cleaning, let the alcohol clean it out for ya. Heads and fores should clean it up. My .02$
- HDNB
Re: still build
plug the holes and fill it with 7% pickling vinegar. wait 12 hours. it will clean the copper off of the copper. wipe down what you can with a rag and flush with *lots* of water. season with the high abv wash recommended ^^^
that would give me the confidence to run a sippin' wash.
now i drink for evil.
- Mikey-moo
Re: still build
Can you be more specific as to your extensive cleaning runs?
- WooTeck
Re: still build
I started off with a water run for about 30 mins to check to make sure every thing way safe (checking with a mirror).
ran a mix of 5l of vinegar and 10l of water steaming for 30 mins and then pulled through a few pints.
ran a mix of old strong cider and water through.
at this point I was unimpressed by the smell.
soaked in a mixture of 4l of vinegar water amount unknown. out side sure looks shiny
. inside still unplesent, better but unplesent.
haven't had anymore runs as of yet as im planning to have another soak before.
eck
eck
- HDNB
Re: still build
after many runs of quality likker...i would not describe the scent of the boiler or column as "pleasant"
- T-Pee
Re: still build
That patina'd copper *twang*.HDNB wrote:after many runs of quality likker...i would not describe the scent of the boiler or column as "pleasant"
tp (and a bent nose)
Handy Links:
The Rules We Live By
GA Flatwoods sez
Handy Links:
GA Flatwoods sez
- SoMo
Re: still build
TP's probably right here, but I like the smell of steamy copper and backset! Your results may vary.T-Pee wrote:That patina'd copper *twang*.HDNB wrote:after many runs of quality likker...i would not describe the scent of the boiler or column as "pleasant"
- WooTeck
Re: still build
thanks for all the advice guys. think ill give it one more soak and batch of runs then just go with it till i make something tasty.
eck
eck
- WooTeck
Re: still build
so im thinking of rebuilding the still reasons for this are
- A. to save space. the condenser is 1m long so it sticks out a fair bit.
- B. the circled part has started to bend. see bellow.
- C. i want to add the digital parrot
- Oldvine Zin
Re: still build
Cool drawings !!! Can't wait to see witch one you build
- ericrichards420
Re: still build
Woo Tech I recommend you using these components these are what I plan on using with 240 vac 5500 W element.
http://www.auberins.com/index.php?main_ ... cts_id=332" onclick="window.open(this.href);return false;" rel="nofollow
- moosemilk
Re: still build
Woo, consider putting a brace from your column to condenser (on a diagonal). Something that either clamps or is permanent. This will help keep it from bending from the weight of your leibig, especially filled with water. Kinda like the brace you see on the bigger caps on pot stills from the lyne to the cap.
- WooTeck
Re: still build
already have a controller. just looking to rebuild the column.ericrichards420 wrote:Woo Tech I recommend you using these components these are what I plan on using with 240 vac 5500 W element.
i thought about that but i figger 54/35 copper pipe should be strong enough to hold the leibig. the 15mm was a little to thin. on the new build the condenser will be vertical/parallel to the column instead of at the angle. my thoughts are it should be able to hold its shape better.moosemilk wrote:Woo, consider putting a brace from your column to condenser (on a diagonal). Something that either clamps or is permanent. This will help keep it from bending from the weight of your leibig, especially filled with water. Kinda like the brace you see on the bigger caps on pot stills from the lyne to the cap.
- moosemilk
Re: still build
Build yourself a nice shotty! Then you'll be part way there for a really nice flute set-up . . . because you KNOW one day it's going to happen lol. That's my project once i get my electric running . . . need cable and ran out of money over holidays. DOH! Just over a week . . . and FINALLY be running electric (fingers crossed).
- WooTeck
Re: still build
i did think about a shotty build and i do want to flute. only thing holing me back is the cost and i dont think i have the ability or access to the tools i need for a complex build. ill jump on something simple to get me back up and running and the liebeg would just be sitting there gathering further dustmoosemilk wrote:Build yourself a nice shotty! Then you'll be part way there for a really nice flute set-up . . . because you KNOW one day it's going to happen lol. That's my project once i get my electric running . . . need cable and ran out of money over holidays. DOH! Just over a week . . . and FINALLY be running electric (fingers crossed).
- Swedish Pride
Re: still build
quick and easy fix for the bent issue would be just to go up to 3/4 inch from the riser and then back to 1/2 just before the liebig, that should be plenty strong.
How is it a pain to set up, to me it looks very simple, just two parts right, riser and condenser?
Don't be a dick
- WooTeck
Re: still build
i dont have any 3/4" id need to buy a 1m for a small fix. on the other hand ive got .5m of 53mm and 1m of 35mm.Swedish Pride wrote:quick and easy fix for the bent issue would be just to go up to 3/4 inch from the riser and then back to 1/2 just before the liebig, that should be plenty strong.
i have a bad habit of missplacing my tools
since i will soon have a dedicated room the tool issue will be sorted as ill have somewhere to put them but as the room is small i will need the leibig vertical.
- Swedish Pride
Re: still build
same as that myself mate, tools all over the place , bar the toolboxes that is... :/
Don't be a dick
- WooTeck
Re: still build
nothing worse than being set up ready to run then discover you can only hand tighn the liebeg
DirtDirt
Re: still build
The drum has a lining I'd not use that as a fermenter no telling what was it and if it leached into the lining buy a food grade plastic barrel for fermenting I can get them here for around 60$ new
"Death is only the beggining"
- WooTeck
Re: still build
the drum is for storing 95% drinking alcohol. i think its a food grade epoxy. i cant see any potentual issues as the alcohol content will be max 15%DirtDirt wrote:The drum has a lining I'd not use that as a fermenter no telling what was it and if it leached into the lining buy a food grade plastic barrel for fermenting I can get them here for around 60$ new
