Evening all...
I have a quick question. I have a few different batches of sweet feed that I put on wood. It went on wood about 3 months ago at about 60% ABV. It was looking and tasting quite nice so I pulled it off and bottled it.
This is the longest I have aged anything on wood so far...question is: any reason to let it sit in the bottle for a bit (aside from more time...) before sippin?
Sorry if the post shows up twice... I posted and then I never saw it land!
Bottle to beverage...
- rgreen2002
HD Glossary - Open this
Re: Bottle to beverage...
3 months is still young. More time would improve it obviously. But, if you don't have enything (mature) to sip, then by all means...pop your cork!rgreen2002 wrote:...about 3 months...any reason to let it sit in the bottle for a bit (aside from more time...) before sippin?...
Now you are at the point where you can learn what "age" does to a whiskey. Enjoy.
I believe it helps to let it age for a while after it comes off the wood. I age mine for a few years on oak and like to let it set for a couple of months after it is strained off and let it breath whenever I think about it. I Try to save some white likker from each run to hold me over to the next....that keeps me out of the aging stock. Just my 2 cents .... If you like it then it's all good.
To each his own
- NZChris
It will age better on the wood, so I only bottle enough for my needs, usually one bottle at a time.
A rest after dilution is beneficial, so try to plan ahead a few weeks.
- rgreen2002
In the same vein... has anyone ever tried adding "new" wood after a while or maybe changing the wood all together? Just wondering if it might speedup/hinder the process or change some other unpredictable...
Jump in...the water's fine!
Go ahead and re-wood. (120 proof, right?)
Have you tempered it already? If so, the whiskey will pick up different flavors from the wood. I don't like to re-wood after tempering from 125-130 proof (my preferred aging strength). Even after I pull it off wood, I still keep it at 125 proof. I temper to drinking strength when I bottle...for drinking.
- rgreen2002
still_stirrin wrote:Jump in...the water's fine!
Sadly I have already cut it down to about 90 proof. I will let it rest in the bottle for a little while and see how she goes. What I didn't want to do was leave it on wood chips for too long and since it was tasting darn good I thought I would pull it off and see.
