CM water temperature control
Klein
Post by Klein »
Hey guys I have finished my other projects and was looking for another project to tinker with.
Background information
I have the t-500 reflux still and I have removed all the synthetics (other than the top cap).
I also made an attachment for the lid so I also have a pot still as well.
For my pot still head I also made a 32” Liebig ¾” over ½” as well as an inline parrot.
I am using well water, so like others I have the same problem of water pressure variations. To solve this I have a bucket on the roof trusses with a float valve to keep it full and at a constant level. As well as a pipe on the side at the bottom for the water to flow with gravity down into my still. This setup Works well and has been tested with cheap garden hoses mounted the same way the permanent pipes would be laid out on the wall. Before I do the gravity fed system I’d like to try another idea, due to the fact that I could see possible problems with that setup, like a blocked pipe for example.
Next project
My next idea is to try to electronically control the temperature of the cooling water. They (still spirits) say to run it between 50 and 65 degrees Celsius. I would like to be able to set it to keep the water temperature around about 54 degrees Celsius. What I’m not sure about is what controller id use, but the idea would be to have a thermocouple and a small proportional valve.
The idea is that maybe I could use this system to replace the gravity system and I could also take it when I move out. I would also have it housed in a pvc box that would be large enough that I can later add more safety features.
Before anyone says it, no I am not leaving it alone! When I try to keep it set at the low 50 range it often drops into the 40s.
If anyone would be able to help point me in the right direction that would be a huge help.
This topic has 7 more replies
Register Login
