Really hot ferment!
Really hot ferment!
So I went away for a week, before I left I made a 25 gallon sugar wash with corn and rye 10%ABV and I used EC-1118 yeast because it works good when it's cold and I find that it's a pretty clean yeast. It's winter here so I put my little heater on my fermenter barrel and told my girlfriend to not let the temperature get over 80 degrees F. I have a thermometer in my fermenter that you can pull out and check the temp. So anyway when I came home I checked the temp and it was 120 degrees! It was done fermenting but hot as hell! My girlfriend said she forgot to check the temp, even when I called to remind her. What are the consequences of fermenting a sugar wash at 100+ degrees? A shit load of heads and barely any hearts? I was going to strip it first. I have a column/flute still, would refluxing while stripping it clean it up?
Any ideas or suggestions would be appreciated!
Never argue with a fool, onlookers may not be able to tell the difference.
Re: Really hot ferment!
That sucks... You'll just have to run it and hope for the best... Make sure you collect in many small jars, just in case...
- Still Life
Those yeasts were sweating like a workout.
Gives new meaning to aerobic phase.
Run it like Rad says.
You'll probably have some off flavors. Next time, buy a temperature controller and relax in the knowledge that technology is helping manage the process ...
http://www.ink-bird.com/products-temper ... tc308.html" onclick="window.open(this.href);return false;" rel="nofollow
________________
- Master Distiller
It sounds like you're due for an "upgrade"....in girlfriends, that is.TedL wrote:I went away for a week...so I put my little heater on my fermenter barrel and told my girlfriend to not let the temperature get over 80 degrees F....when I came home I checked the temp and it was 120 degrees! It was...hot as hell! My girlfriend said she forgot to check the temp, even when I called to remind her...Any ideas or suggestions would be appreciated!
- FreeMountainHermit
Got one. plug n play. I love it. Currently plugged into my pepper seeds germination bed.greggn wrote: Next time, buy a temperature controller and relax in the knowledge that technology is helping manage the process ...
Blah, blah, blah,........
SS she is dumb as a doorknob,. Fortunately she doesn't live with me.still_stirrin wrote:It sounds like you're due for an "upgrade"....in girlfriends, that is.TedL wrote:I went away for a week...so I put my little heater on my fermenter barrel and told my girlfriend to not let the temperature get over 80 degrees F....when I came home I checked the temp and it was 120 degrees! It was...hot as hell! My girlfriend said she forgot to check the temp, even when I called to remind her...Any ideas or suggestions would be appreciated!It seems you don't fully have her attention any more.
I'll try collecting in small jars and hope for the best. What if it comes out to be complete shit? I guess a waste of 25+ pounds of sugarrad14701 wrote:That sucks... You'll just have to run it and hope for the best... Make sure you collect in many small jars, just in case...
I thought about getting a temperature controller but I'm not sure what to hook it up to.greggn wrote:You'll probably have some off flavors. Next time, buy a temperature controller and relax in the knowledge that technology is helping manage the process ...
I use an aquarium heater to help with winter temps. Cheap and fairly reliable.
Experience is something you don't get until just after you need it.
TedL wrote: http://www.ink-bird.com/products-temper ... tc308.html" onclick="window.open(this.href);return false;" rel="nofollow
Use your existing little heater plugged into the controller and tape the sensor from the controller to the side of your fermenter with something over that to act as an insulator (old sock,tee shirt, etc.) and you're golden.TedL wrote: It's winter here so I put my little heater on my fermenter barrel and told my girlfriend to not let the temperature get over 80 degrees F. I have a thermometer in my fermenter that you can pull out and check the temp. So anyway when I came home I checked the temp and it was 120 degrees!
No more 120 degrees !
- Master Distiller
But is she pretty...TedL wrote:SS she is dumb as a doorknob,. Fortunately she doesn't live with me.still_stirrin wrote:It sounds like you're due for an "upgrade"....in girlfriends, that is.TedL wrote:I went away for a week...so I put my little heater on my fermenter barrel and told my girlfriend to not let the temperature get over 80 degrees F....when I came home I checked the temp and it was 120 degrees! It was...hot as hell! My girlfriend said she forgot to check the temp, even when I called to remind her...Any ideas or suggestions would be appreciated!It seems you don't fully have her attention any more.
Deo Vendice
Deo Vendice
We all have our assets.
