Is a container like this safe for a fermentation container?
I'm trying to follow rule #3. Are you?
http://homedistiller.org/forum/viewtopi ... =35&t=5090
Re: Is a container like this safe for a fermentation contain
yep that will work
Imo you can get a better price though...
Deo Vendice
Deo Vendice
Thanks .. . are there online sources you can recommend .. or are there hints for places that would be good to check locally?jb-texshine wrote:Imo you can get a better price though...
Those are safe for fermenting but, keep in mind, those are sealed-lid containers and will be difficult to clean and sanitize. The only opening is that 4" port.
________________
A con saw wouldn't be long fixing that.
I thought i was wrong once,
But then i found out i was mistaken.
Kill the women, and rape the men.
- Single Malt Yinzer
They are hard to clean. If you're ok with open ferments cut the top off and you're good. I used mine once but found it way too much of a pain to deal with the small hole. Most come with a pressure relief plug that isn't airtight enough to use for longer sanitary ferments.
For price - there's a weird thing that the 15 & 30 gallon barrels cost more than the others. I got my mine for $15 or $20. I could have gotten a 55 gallon steel plastic drum for a couple bucks less.
- rgreen2002
Agree with a better price. Check craigslist in your area. I picked up my 40 gallon for the price of the 15 gallon in the OP post. If you get a bigger barrel you can make a lid when you cut the top off:
HD Glossary - Open this
33 gallon blow molded trash cans work very well... and you can buy them for less or for more depending on where you shop
Look at the markings on the bottom to figure out what material you have... if and when your done with them they become trash cans...
happy stillin,
FS
you might look at large ice chests as well they work too... removable top food grade plastic drums both ring and screw type are out there if you just look... try craigslist
happy stillin,
FS
Do it Safely read The safety section: http://homedistiller.org/forum/viewforum.php?f=33
New Distillers Reading: http://homedistiller.org/forum/viewforum.php?f=46
Hookline's Basic Still Designs: http://homedistiller.org/forum/viewtopi ... =1&t=18873
The small opening will give you many regrets long term otherwise it's fine.
_______________________________
15 gallon keg pot still
15 gallon Brew King boiler
2 35 gallon fermenters
- Truckinbutch
Check lining a ferment barrel with a clear plastic garbage bag like SRD and I do .
Truckinbutch wrote:Check lining a ferment barrel with a clear plastic garbage bag like SRD and I do .
Is "clear" really a factor ?
________________
