Copper bits in Potstill changed color.
Winebibber
Post by Winebibber »
Hi all,
I recently finished a 28 Lit. of Wineos plain ol sugar wash stripping run in my simple SS pot still with copper worm condenser (no reflux column right now). I used to put few pieces of thoroughly cleaned copper as boiling chips in the potstill. After successfully completing the run, I found that the copper chips were clean and shining as before, so I simply cleaned them with water and reused them for the spirit run. My low wines were also very clear.
After the spirit run, when I removed the copper bits, they were badly discolored. My final distillate started at 79% abv, I made the possibly proper cuts and collected up to 11% abv. The distillate is sparkingly clear with apparently no bad taste or smell.
I'm worried about the discoloration of boiling chips however. Is it normal or I am doing some mistake? I'll be thanklful for any guidance.
Discolored copper bits
greggn
Re: Copper bits in Potstill changed color.
Post by greggn »
What's the pH of the water used to dilute the low wines for your spirit run ? I'll bet it's slightly alkaline ( 7.4 - 7.8 ).
________________
Winebibber
greggn wrote:What's the pH of the water used to dilute the low wines for your spirit run ? I'll bet it's slightly alkaline (7.4 - 7.8).
I did not use any water to dilute the low wines. I collected the low wines starting at 56% abv and ended at 13% abv. The average abv was 36%, so I used it straight for the spirit run.
Make sure it is copper and not an alloy or plated. Does it bend and scratch like copper?
Winebibber
NZChris wrote:Make sure it is copper and not an alloy or plated. Does it bend and scratch like copper?
Yes, I think it is pure copper. It bends and scratches easily, and is soft enough. It was a copper plate of around 2.5" diameter and 1.2 mm thick, cut into four pieces . Similar to another plate available with me posted below. I have now socked those bits in vinegar and I'll see if they can come clean after few hours.
Another copper plate
Winebibber
I soaked the copper bits in vinegar for about 10 hours and cleaned them with water and a scrub. Now they are clean and sparkling. It is not clear to me why this discoloration happened. :? Any idea please?
Bits after cleaning.
I have always run copper in my boiler , I have never seen it go that colour.
Did you drain the boiler and leave the copper in there for a while before removing it, oxidization could be one thing that might make it go that colour.
Winebibber
Saltbush Bill wrote:I have always run copper in my boiler , I have never seen it go that colour.
Yes, after draining the boiler fully I let it cool down for an hour or two before picking up the bits. Does the oxidization process starts that fast? Should I worry about the quality of the distillate or continue using those copper bits in my next runs?
Winebibber wrote:Yes, after draining the boiler fully I let it cool down for an hour or two before picking up the bits
I think that is your problem then, Ive seen copper go that colour when left wet and in a damp environment.
Winebibber wrote:Should I worry about the quality of the distillate or continue using those copper bits in my next runs?
Not in my opinion, looks like perfectly good copper to me.
greggn wrote:What's the pH of the water used to dilute the low wines for your spirit run ? I'll bet it's slightly alkaline ( 7.4 - 7.8 ).
Greggn would you like to explain to me why you think the PH was responsible for this issue and how it made the copper go that colour? I find it interesting that any thing and everything that cant be explained easily is blamed on PH.
Winebibber
Saltbush Bill wrote:I think that is your problem then, Ive seen copper go that colour when left wet and in a damp environment.
Thanks Saltbush Bill, for the kind advise. I'll go ahead with my next batches with due care for this. :)
greggn
Post by greggn »
Given the OP's statement above that suggested the discoloration occurred *during* the run ... not from sitting around some time afterward. Since it was a sugar wash I thought water chemistry was a reasonable culprit. I profusely apologize for my silly, uneducated assumption.
________________
Winebibber
greggn wrote:>Greggn would you like to explain to me why you think the PH was responsible
Oops! I am sorry Greggn, for your inconvenience. As a novice, I didn't recognize the importance of idle time element lapsed before taking out and examining the bits after the spirit run. I couldn't represent the whole incidence in proper words. My bad! :oops:
Thanks for all the thoughts, guys.
