Lyne Arm Angle
WooTeck
Re: Lyne Arm Angle
Post by WooTeck »
thecroweater wrote:yes there was a difference, i wouldnt say profound but noticeable and maybe 10 to 15 percent difference in ABV as well
interesting. id guess you would change the angle depeding on what you were running and what you were looking for. out of interest what angle did you choose more often? i like my spirts smooth for that im willing to sacrifice some flavour.
my plan is for the lyne arm to taper down from 52mm to 35mm to encorage some reflux.
Bushman - [url=http://homedistiller.org/forum/viewtopic.php?f=16&t=19858#p6888255]New design looking for suggestions[/url] wrote:
I also did some more research googling the topic ... I found that a steep ascent going up say 45 degrees the alcoholic vapours have to fight their way uphill. Therefore, they cool down slowly resulting in a very smooth and high-proof distillate. Parallel outflow (horizontal lyne arm) the alcoholic vapours almost glide to the cooler. Therefore, they cool down moderately resulting in a rather smooth distillate. And last a steep descent (-) of the vapours the alcoholic vapours rapidly fall down to the cooler. Therefore, they cool down quickly resulting in a harsh but more low-proof distillate.
i read this in an old bushman thread. how dose it fit in with your exp?
thecroweater
Re: Lyne Arm Angle
Post by thecroweater »
if you strip then you can go steeper and it really depends on what you want, prolly 15 to 20 degrees i think
Odin
Re: Lyne Arm Angle
Post by Odin »
Lyne arm rising up gives you more passive reflux and up to 0.2 extra redistillation. When you distill slowly. Lyne arm going down ... 1 distillation only instead of 1.2.
Odin.
myles
Re: Lyne Arm Angle
Post by myles »
It all depends on vapour speed and surface area.
There is one real easy way to know if it makes any difference. Simply measure the vapour temperature going into the arm and coming out. If they are the same then you know the arm is doing nothing.
Remember the purpose of the taper on the big onion stills? It is to maintain the vapour speed to compensate for the reduction in volume as the vapour cools.
Fredistiller
Re: Lyne Arm Angle
Post by Fredistiller »
As I am rereading this very intresting topic, some questions came to my mind.
As you guys are using the word "taper". Do you actualy mean a conical shape? Of the lyne arm, the column, both? Couldn t get an answer in the glossary, nor from dr google. :D 8
Second, about the use of an common hobby sized horizontal lyne arm made from a pipe: When the first foreshots vapours takes off, and met the "cold" room temperature in the lyne arm, I assume they would condense...And stays there, because the arm is horizontal. Could it be an issue? Contaminate the vapors that follow? Or doesn t it work like that..
Thanks in advance!
Re: Lyne Arm Angle
Fredistiller wrote:....As you guys are using the word "taper". Do you actualy mean a conical shape? Of the lyne arm, the column, both?
Yes, it is a conical taper, and yes, for both the tower and the lyne arm.
The taper compensates for the "cooling" vapors which, as they liberate some of its heat to the copper, cools and since density of a vapor is a function of the temperature, the density increases. When the density increases, the vapor velocity slows (constant mass flow, remember?). To compensate for that reduction in speed, the tube is tapered...so the velocity remains (more) constant.
If the vapor speed were to slow too much, it would indeed condense more which would affect the product throughput stability. So, like myles said, the taper is to maintain vapor velocity in both, the tower and the lyne arm.
Fredistiller wrote:...When the first foreshots vapours takes off, and met the "cold" room temperature in the lyne arm, I assume they would condense...And stays there, because the arm is horizontal. Could it be an issue? Contaminate the vapors that follow? Or doesn t it work like that...
This is somewhat explained in the answer above. The intent of the taper is to maintain vapor velocity (throughput). In a hobby sized pipe lyne arm, the velocity is typically much faster and as such, won't liberate excessive amouts of the heat it carries. So, it likely won't condense much, if at all.
OK, there may be a little condensation at the beginning before the still head is up to temperature (when the lyne is "cold", as you say). But that first bit, with the lowest boiling point and first to condense would be reheated by the vapors following it in the pipe such that it again vaporizes and travels on to the product condenser.
Will it "smear"....of course...a little. That is why the lines between foreshots and heads are "fuzzy". But by the time your still is actually producing, it will be up to temperature and you won't get appreciable condensation inside a horizontal lyne arm...unless it is excessively long (like more than 20 diameters). OK?
Fredistiller
Re: Lyne Arm Angle
Yep that makes sense, thanks!!
Alchemist75
Re: Lyne Arm Angle
Post by Alchemist75 »
I guess I'm late to the conversation but I've fooled around with lyne arm angles, diameters, different materials and novel configurations. It definitely has an affect on how fast a run will progress.
A skinny, well insulated and downward angled design will run off the fastest and smear the most. A naked copper lyne arm of the same type will run slower. On the other extreme, a wider spiral riser lyne arm will run fast for a bit at full tilt but then it'll slow down and begin refluxing dragging the run on longer and flattening it all out. Run that same spiral at a lower energy input and you get a proof bump and less smearing. I operate a reasonably small set up but I actually have 4 separate possible lyne arm set ups that I can use for different purposes and they all behave very differently.
SOLVE ET COAGULA, ET HABEBIS MAGISTERIUM
Re: Lyne Arm Angle
Alchemist75 wrote:I guess I'm late to the conversation but I've fooled around with lyne arm angles, diameters, different materials and novel configurations. It definitely has an affect on how fast a run will progress.
Nice write up and confirms a lot of what you can find on line but in better detail. This post reminds me of a comment I made to a member earlier today that questioned another members comments because he probably hadn't tried it. If we read enough facts and members like you are willing to share their results we all benefit by the the experiments and tests done by others.
Alchemist75
Re: Lyne Arm Angle
Shape and size do matter even at the hobby level. The engineering of it all gets me hot and bothered.
Kareltje
Re: Lyne Arm Angle
Post by Kareltje »
Research and science is just a way of testing the answers to our questions. In scientific research the questions we as hobby distillers have, are answered by trained people with adequate equipment.
I remembered this http://whiskyscience.blogspot.nl/2014/10/copper.html" onclick="window.open(this.href);return false;" rel="nofollow
There is a figure in it about the angle of the lyne arm and its influence on taste.
BugHunter
Re: Lyne Arm Angle
Post by BugHunter »
If you have a 90 degree elbow at the top of your column, with a tri-clamp flange on it, then another 90 or 45 degree elbow to your arm, you can rotate it via the tri-clamp to get whatever angle you want to try out.
But judging from all the experienced folk who posted earlier, it doesn't sound like it makes much difference at small scale.
But the tri-clamp also makes it easier to clean and store the still in addition to giving the option of trying different angles.
Alchemist75
Re: Lyne Arm Angle
I think seeing the difference is a matter of going to pathological extremes in terms of shapes and configurations. The three basic angles may not produce major variation in terms of how a run progresses small scale but start fooling around with more outlandish stuff and then it becomes quite obvious.
HDNB
Re: Lyne Arm Angle
Post by HDNB »
Alchemist75 wrote:Shape and size do matter even at the hobby level. The engineering of it all gets me hot and bothered.
i think you hit on a key point earlier too...insulation makes a huge difference. I had insulation on top of my kettle that was contributing to smearing in a big way. Even without testing, i would believe your experience noted above about the same effect on insulated lyne arm.
now i drink for evil.
Garouda
Re: Lyne Arm Angle
Post by Garouda »
HDNB wrote: ↑Thu Nov 02, 2017 6:58 am
I react a bit late, sorry.
Insulating your Lyne arm is nonsense, I'm afraid.
There's an important feature of all those pot stills: natural reflux.
Look at the shape of Charentais alembics, the bulb shape and size are designed to cause some reflux!
Also, in France Cognac can only be distilled from the end of fermentation till the last day of March, in cold places.
Do you notice any insulation on pot stills in Scotland?
See also: viewtopic.php?p=7767455#p7767455
The column is insulated, but not the Lyne arm...
"In wine there is Wisdom, in beer there is Freedom, in water there are bacteria."
Benjamin Franklin
"In moonshine there is Rebeldom"
Garouda
Dan P.
Re: Lyne Arm Angle
Post by Dan P. »
Garouda wrote: ↑Fri Feb 09, 2024 5:33 am
Also a bit late, sorry! I think he was referring to insulating the Lyne arm as being a bad idea because it causes smearing ie reduces reflux.
I've been reading (re-reading?) this ancient thread. Interesting stuff. It seems myles is no longer here to defend his ideas, but I'd say that in his estimation of Lyne arm angle on large Scottish commercial stills he is neglecting to factor in volume of vapour to area of Lyne arm surface (and thus coolant effect resulting in reflux). The increase in volume of a tube is exponential, eg a 1" tube will have a nominal area of 0.8", a 2" diameter tube will have an interior area of nominal 3". Thus, given an equal flow rate of vapour, the bigger the tube the less reflux, if we were to judge reflux as being in correlation to exposure to the tube wall, which might or might not be entirely accurate.
Anyhoo, best thing is to try it and see. I used to be skeptical, but my current pot still has a rising Lyne arm and I can hear the reflux dripping back down into the pot, but I think that is more to do with the fact that it has an enormous cap. I actually get too much purity out of it, not sure why.
30xs
Re: Lyne Arm Angle
Post by 30xs »
Dan P. wrote: ↑Thu Nov 05, 2026 2:27 pm
Maybe you could get away with a slightly faster takeoff rate to get a pot stilled product of your preference? That would sort of affirm the OG’s original posts that angle is negligible at the hobby level.
Dan P.
Re: Lyne Arm Angle
Post by Dan P. »
30xs wrote: ↑Thu Nov 05, 2026 6:06 pm
Tbh I'm still pretty skeptical about the Lyne arm angle at any level, I just think it's not necessarily any less (or more) effective at any scale. I'd say heat management is the principal factor by a wide margin, and secondary to that, in the case of Scotch, the size of the cap. And also a lot of marketing hokum on the part of the distillers, obviously (and fair play to them!).
In my own case what's odd is that if I crank up the heat, the abv% stays pretty much the same, but the product is smeared to hell.
PalCabral
Re: Lyne Arm Angle
Post by PalCabral »
I have been inspired by this thread in the past and when I made my mirabelle plums brandy last year I tried the lyne arm 45 degrees up style. Since I didnt have anything to compare with, I cant really tell if it made a difference or not, but it made some sense at the time.
Typically I aim the lyne arm horizontal or 45 degrees down based on what makes sense from a collection point of view. Unfortunately, I never recorded the lyne arm direction so I can't really make any comparisons. However, now that I need to make three spirit runs to finish my Red Diamond High Rye Bourbon project I will test the horizontal and the 45 degrees down options. Let's see if it is possible to detect differences.
Dan P.
Re: Lyne Arm Angle
Post by Dan P. »
I think distillation is for madmen and this is just one of the many symptoms!
Mirabelle sounds delightful! I am working on quince myself at the moment. Good luck to us both!
Re: Lyne Arm Angle
Post by Novice »
Angle counts,dwell time also. Vapor speed matters.
Re: Lyne Arm Angle
Post by Novice »
Dan P. wrote: ↑Fri Nov 06, 2026 1:43 am
Try a rye mash on the dribble output,45° up about 3-4' lyne arm same wash straight down. I think you'll see a difference .
Re: Lyne Arm Angle
My 2 cent's worth.
At Hobbie scale, I don't think arm angle makes a noticeable difference in character.
Mostly we use 2" copper pipe or smaller tubing for vapor, not a large cone shaped lyne arm like distilleries use.
For potstilling, folks often use a riser. If there was a reflux advantage to having the arm pointing up, the riser would have already done the job.
The one advantage to having the arm pointed up, would be to return puke, foam and even entrainment back to the boiler.
In other words, if it ain't 100% vapor, it doesn't get past. Much like a slobber box would do.
Maybe someone could make a copper slobber box for comparison with the different arm angles.
For the experiment, think wooden box screwed together, with very thin copper lining. Something built for $30 :wink:
Re: Lyne Arm Angle
I had a 2” 500ml riser , a 2” 1000mm rising Lyne arm at IIRC about a 30° angle with the hope that it would let all the puke fall back to boiler . Alas on a Whisky stripping run it still puked and puked and kept on puking .
Re: Lyne Arm Angle
Found the pics
Re: Lyne Arm Angle
That's an impressive puke and it shows how little arm angle matters when it happens. :lol:
PalCabral
Re: Lyne Arm Angle
Post by PalCabral »
Yummyrum wrote: ↑Fri Nov 06, 2026 6:28 pm Alas on a Whisky stripping run it still puked and puked and kept on puking .
This is when the Distilling Conditioner came into your life, Yummy? I’ve not had any foam ups since I picked up on your advise.
I am interested in the tapered riser design, especially for stripping runs, which is also discussed in this thread. It seems perfect for providing high copper contact while promoting a high undisturbed vaper flow. Win-win. I am curious what fellow distillers on HD using tapered risers say about them.
Re: Lyne Arm Angle
PalCabral wrote: ↑Fri Nov 06, 2026 11:29 pm
LOL , I am a convert to Smithicone antifoam for sure Pal . That pic was back around ten years ago when the best I used was vege oil .
I’m also interested in the tapered riser and lyne arm . I posted the above to show that even a 2” setup is no prevention of puke .
I do use about a 4” 600mm riser on my Rum setup and even that will still puke .
Puke bubbles have a finite size . Perhaps at hobby size , the bubble size to riser ratio is small whereas in a large Scottish Pot still , the ratio of bubbles to riser diameter is so much bigger that they do actually collapse down , unable to hold them selves up .
PalCabral
Re: Lyne Arm Angle
Post by PalCabral »
Yummyrum wrote: ↑Fri Nov 06, 2026 11:46 pm
Some Scottish stills are equipped with an Ogee, an oval expansion chamber, at the base of the neck. It differs from a boil boil in that it is smaller and has the oblong shape rather than being spherical. I am guessing the Ogee is some sort of puke preventive measure, without disrupting the vapor flow too much. A boil ball would have a very similar effect on the vapor flow as a copper dome/onion will have, creating a lot of disruption and passive reflux, but perhaps the small volume and shape of the Ogee makes a difference.
Copperhead road
Re: Lyne Arm Angle
Post by Copperhead road »
I would love a big full copper swan neck potstill... the ultimate for brown spirits IMO
I would like the ability to use Gas, All the bigger 120 Litre copper boilers i have seen are designed to be run with elements. :thumbdown:
