Need Help Designing a Condenser
NADERHANNA1719
Post by NADERHANNA1719 »
Hi Everyone,
I'm building a 30 gallon hobby still, which I'm running pretty hard until I settle on a Arak recipe.
I designed the boiler and head which were fairly easy, but I'm having trouble designing the condenser.
I was thinking of building a 10 gallon condenser with 1/2" copper tube worm inside, but space is an issue, as this is in my basement, so I'd like to go with a shotgun condenser, but I have several questions.
I'm building a pot still, similar to a traditional moonshine still, but I've only ever seen shotguns on column stills is there a reason for that?
If I were to build a shotgun still, how many tubes should I put in it, and what diameter?
I know you're going to say its related to BTUs not boiler size, but I don't know the BTU's. I'm using a homemade double ring gas burner & don't know the output.
If I do go with the traditional worm condenser is 1/2" inner diameter tubing ok for this size still and how many feet of tubing would suffice?
At this size should I consider 3/4" tubing?
Any advice would be greatly appreciated.
Thanks,
Nader
This topic has 16 more replies
Register Login
