Tower of Power
Tower of Power
Has anyone used the Blichmann Tower of Power 240v controller for distilling? Have a question about temperature probe placement.
Re: Tower of Power
I'm assuming you have the electric controller model instead of the gas controller one.
Don't use the temperature probe for distilling*. Instead, put it in Power Control "ON" mode to modulate the power by dialing in a percentage.
Crank it up high to get the boil going, then dial back the percentage to get a fine pencil lead product stream coming out of the spout.
*You can't run a boiler by temperature. A reliable product stream can only be controlled by power input to the heater.
I've never used the Tower Of Power, and I'm only going by the manual's instructions. Maybe someone with first hand knowledge will have better advice.
Re: Tower of Power
When I saw tower of power I was thinking 69-70's R&B. Gettin old as gold. As the fizzman said and we are also assuming that you are still running a pot still. And also taking it that you own one already. If you don't there are other options for less money.
Re: Tower of Power
I have not purchased yet. I've looked at other controllers, most seem like home built junk compared to the ToP. Would love some ideas. Want 240 for sure.
Re: Tower of Power
Running a 13 gallon milk can with a 2 foot, non-reflux, copper column.acfixer69 wrote:When I saw tower of power I was thinking 69-70's R&B. Gettin old as gold. As the fizzman said and we are also assuming that you are still running a pot still. And also taking it that you own one already. If you don't there are other options for less money.
Re: Tower of Power
If you don't have one, there's DEFINITELY less expensive options. C'mon you controller guys. Where are ya?
Re: Tower of Power
I have some time. Really want electric to do runs in the summer. Can't use gas in private when it's 80 outside, too hot in the garage!
Re: Tower of Power
There are many controllers out there and you can spend as much as you want. The one that stilldragon sell is as good as any and if you are the least bit handy can assemble it. I'm not affiliated in any way but giving you an option.
http://stilldragon.com/index.php/diy-la ... oller.html" onclick="window.open(this.href);return false;" rel="nofollow
Re: Tower of Power
Electric is the way to go for most in the burbs got to go inside and for me it was the only way.Burl Jerkins wrote:I have some time. Really want electric to do runs in the summer. Can't use gas in private when it's 80 outside, too hot in the garage!
Re: Tower of Power
That does look pretty simple and the price is right. Do you use this setup?acfixer69 wrote:There are many controllers out there and you can spend as much as you want. The one that stilldragon sell is as good as any and if you are the least bit handy can assemble it. I'm not affiliated in any way but giving you an option.
Re: Tower of Power
Many many distillers world wide are using the option that AC posted up , The other thing is way over priced for what you need.
Re: Tower of Power
That does look pretty simple and the price is right. Do you use this setup?Burl Jerkins wrote:acfixer69 wrote:There are many controllers out there and you can spend as much as you want. The one that stilldragon sell is as good as any and if you are the least bit handy can assemble it. I'm not affiliated in any way but giving you an option.
Yes very similar to it but I built mine before the evolution of controllers. I wish that choice was out there 8 years ago.
Re: Tower of Power
build your own. i built mine. not that hard. might cost you about a hundred dollars with parts.
I'm just the bank and the mule
post your still pics here
http://homedistiller.org/forum/viewtopi ... 16&t=66917
Re: Tower of Power
How big is your element??
If it is fairly low capacity you probably don't need a controller at all. What do you experts say?
Re: Tower of Power
That's why I sent him that direction one stop and 50 bucks and at your door.nuntius01 wrote:build your own. i built mine. not that hard. might cost you about a hundred dollars with parts.
Re: Tower of Power
I am running the controller kit from still dragon on a 5500 watt heater. It works great. I do want to add an ampmeter to it as part of my flute upgrade. I will be fixing a second keg up for runing the flute I am working on and will upgrade the controller as well a bit.
Re: Tower of Power
Thanks folks! Think I will just build one myself. I'm pretty handy, mechanic by trade, can probably figure it out. Have a great electrician's supply store close.
Re: Tower of Power
> https://www.auberins.com/index.php?main ... cts_id=353" onclick="window.open(this.href);return false;" rel="nofollow
I've built two controllers using the Auber SSVRs ... add a meter to facilitate a repeatable process.
________________
Re: Tower of Power
greggn wrote:> https://www.auberins.com/index.php?main ... cts_id=353" onclick="window.open(this.href);return false;" rel="nofollow
Meter? Should probably know what you are talking about, but tell me anyway, lol! Ammeter?
Re: Tower of Power
Yes, an ammeter.
Having grown tired of pencil marks on my first build I added the following to my second build to provide a more consistent and repeatable process.
https://www.auberins.com/index.php?main ... cts_id=490" onclick="window.open(this.href);return false;" rel="nofollow
Yes, an ammeter.
________________
Re: Tower of Power
greggn wrote:> Meter? Should probably know what you are talking about, but tell me anyway, lol! Ammeter?
Yes, an ammeter.
What about a digital PID controller? Any drawbacks other than price point?
Re: Tower of Power
PIDs are useless for distillation. Plenty of threads on that topic.....
_____________________
EXPAT
Current boiler and pot head
Cross flow condenser
Modular 3" Boka - pics tbd
___________________
EXPAT
___________________
Re: Tower of Power
Expat wrote:PIDs are useless for distillation. Plenty of threads on that topic.....
Good to know. Was wondering if I was supposed to search through threads instead of asking questions?
Re: Tower of Power
Yes actually, searching with the "HD Google Search" function and then ask.Burl Jerkins wrote:Expat wrote:PIDs are useless for distillation. Plenty of threads on that topic.....
EXPAT
___________________
EXPAT
___________________
- Hoosier Shine9
Re: Tower of Power
Hi Burl.
I am running the controller from StillDragon, I went to the larger size for ease of building (have fat hands).
I did not put a meter on it, went to Harbor Freight and got a clamp on multimeter, it works but I am still planning on getting a meter on the box.
I have a 15.5 keg with a 4500w 240v element. only reason I don't use the 5500w is because I thought I had a defective one and when I returned it there only had 4500w in stock.
I also am using the Element guard Kit from SD.
Re: Tower of Power
Here's how to use the HD Google Search if you need to know, Burl:
Re: Tower of Power
Hoosier Shine9 wrote:Hi Burl.
box
Thanks for the info.
I pieced together a set up using Auber and Amazon. Gonna be $300 deep by the time it's over, but most of that cost is in the damn cord and plugs, actual controller components were under $150.
Doing a 5500w element, ammeter/voltmeter, circuit breaker/power switch, and an indicator light. 8x8 box with external heat sink for SSR. Pretty excited to put it together when it all gets here. I'll post some pics when I get it going.
Was thinking about the element guard, but I'm using the Dernord heating element that is in a zig-zag shape, so kinda screwed there. Run clean thin wash most of the time anyway. Will just use my gas burner if I do a thicker wash. Going electric so we can run in the summer months.
Re: Tower of Power
I looked at the Still Dragon controller, because I run a still that is very similar. The electrician at work looked at it and said, "Wanna save 50% and a couple hours putting it together?" I now use one of these, works great. This is on Australian Ebay, but I'm sure they can be found elsewhere...
https://www.ebay.com.au/itm/122813028968" onclick="window.open(this.href);return false;" rel="nofollow
A solution is a homogeneous mixture composed of two or more substances. In such a mixture, a solute is a substance dissolved in another substance, known as a solvent. Therefore, whiskey is a solution despite what any tee-totaling jerk tells you.
Re: Tower of Power
Alright. All done. First run with this baby happening Saturday. Did a test with water, pretty impressive, brought 10 gal to boil in 32 min.
Re: Tower of Power
That looks awesome Burl. Good luck on Saturday.
AC
AC
