What'd ya'll make today?
Re: What'd ya'll make today?
Stripped my second batch of hbb. Didn't smell as good as the first batch. For awhile, I was worried I burned it, but it didn't taste burned.
Hopefully it will turn out well for the spirit run.
I only use 10" of packing because I can only fit 10" of packing in my column without adding the extension. Sometimes I add my sight glass and put a half roll of mesh in the middle of it, just so I have something to watch, so that helps a little too. With mesh 10" of height is the equivalent of 2 extra plates i believe. Maybe I'm only Squeezing heads with what I have and I need more packing to Compress themdurty_dunderpants wrote:is there a reason you only go 10"? for me it was just all i have so far! are you capping or just running 1:1 reflux?
I'm capping, for all intents and purposes. When I'm done squeezing heads I simply turn off flow to the reflux condenser (0 reflux) but I don't remove the coil to add a full cap on the column. It's kind of capped on top with what I call a paddle that holds the coil and I can pot still without much vapor leaking. Not enough to worry me. Otis
- jackpinesavage
Just pitched yeast-distillers- into my 2nd attempt at Honey Bear Bourbon this morning. SG 1.035.
JPS
Like a lumberjack but wilder
Ran 3rd generation UJ.
- frunobulax
Yesterday, We made ANOTHER 40 gallon all molasses wash
Spirit run of some port wine brandy i got from my winery hookup. Finally getting the pipeline refilled.
10 gallons RIS + Spirit run on 5 gallons of UJSSM blended to 45% ABV
Finished my 4th stripping run yesterday. So, today is the spirit run. Got about 13 gallons of low wines (80% corn, 12.5% barley malt, 7.5% rye) heating up.
I made an IPA and piggy back the grain into a take off of UJSSM
- Honest_Liberty
just finished Odin's RyeBread SugarHead...hit the gravity right at 10% but the temp was at least 110 when I took my reading. I don't have a second large fermenter so it had to be split between a glass carboy and primary plastic bucket. 11.5 gallons between the two. I need to find out what that translates to in actual ABV.
Also, I'm a bit surprised. I don't know that I have ever seen the airlock start bubbling within 30 minutes. It's already going at a rate of a bubble every 4 seconds. I can't tell what the other bucket is doing because its open top covered with paper towels in between bacon screens, but I assume it has also started.
Sweetfeed 100 proof for drinking white
All grain bourbon for testing my patience
Whatever else is left goes to the Homefree, because, I hate waste
around three litres of Birdwatcher's low wines, I have around 12ltrs all together now so I may take nine and do my spirit run, only concern is not having enough jars to put it all in, nice problem to have though.
Ran 24 gallons rum wash yesterday, yield 2.5 gal keeper
Today running 20 gal gen 2 corn/barley, still in progress.
I just got 8 gallons of brown ale from a brewer friend to run through the 'ol booze pipe. Should make some decent wiskey I think. Anyone have much experience stripping carbonated beer? I read it should be good and flat before its ran.
13.5g/50L keg
26g 4" stripping still
5500watts of fury
5500watts of fury
Working on 20 gallon batch of a cerarye bourbon. Smells just a little bit like heaven
Spirit run on 13 gallons of corn squeezins low wines. Real slow through fores and heads. Took like 8 hours.
Running my low wines off a barrel of sugar wash. Pureed a 5 gallon pot of bananas to put in the thumper tomorrow on the spirit run. While I was at it i used 20 gallons of my sugar wash hot backset to get a new barrel of cooked corn, oats and wheat to Alpha Amalaze temp. Long day today and gonna be a long one tomorrow.
"Virtute et armis" By valor and arms
Let's keep our country free as God has given us.
"Give me Liberty or Give me Death."
Did a spirit run of 6ltrs low wines of Birdwatchers and got 3ltrs for the cuts which I will do tomorrow.
Made a Chinook SMaSH and piggy backing a single malt sugar wash
Re: Cornflakes whiskey
Doing the first stripping run of Odin ryebread whiskey as I am typing this. Couldn't resist tasting it and it's great already!!
- distiller_dresden
mashing in my first deathwish wheatgerm, modified somewhat-
6 lbs DME
1lb Lyle's black treacle
64 oz peach mango 100% juice
5 lbs homemade invert (make 10 lbs batches once a week for my liquor needs, so)
adding 1lb caramel 60L in the last 30 min of the wheatgerm boil
6 lbs DME
I read, I write, I still.
I started my first ever peated whiskey today.
* 42% Peated Malt Barley
* 58% "CBW Bavarian Wheat" Liquid Malt Extract (65% malted wheat, 35% malted barley)
31 gallons, OG 10 60 Pitched last night and it's been bubbling all day long.
What wonderful smells.
Otis
Otis
- likker liker
Sounds fantastic, I've been thinking about starting another batchOtisT wrote:I started my first ever peated whiskey today.
Otis
Stripping run for 20ltrs of Birdwatchers, got 3.5ltrs of product.
- Honest_Liberty
Spirit run, first one yet with a bunch of SF low wines and some that didn't oak well. I'm shocked at the amount of product from 13 gallons at 40%.
Been at this since 10am, still collecting all mid 70s, and it's 7pm, although my proofing hydrometer has been verified at 2% over at 95%, and it showed 46% at 43
20ltrs of Odins Cornflake Whiskey and 1.8ltrs of Odins Easy Gin for dilution tomorrow.
I have a gallon and a half of Still Life's rye distillate waiting and just mashed out 18 more gallons all in anticipation of filling a new three gallon barrel....getting hyped
Just finished a cornflake whiskey spirit run using 6ltrs of low wines. Got about 3.8ltrs going fairly deep into the tails. Making a pale ale tomorrow and the cuts on the spirit run. Always happy when I have a productive day.
Had a half a barrel of sour mash that was ready 6 weeks ago that I never finished running sitting outdoors, so I opened the barrel and saw a good lacto infection going and decided to run it. The proof has dropped from evaporation I guess. Last run of this she started at 160 proof, this run was 130.
Around 105 proof I tasted her and it has a very interesting flavor, nutty with an oaky hint. Gonna strip it down and add it to my all grain low wines. Should be an intetesting second run.
I just put a couple quarts of Uncle Jessies Sour Mash on oak. After a month on oak there's a very nice product.
Ran a feints run, stopped collecting after I started smelling tails, I've already recycled my feints once already so didn't want to chance wasting time and effort for a third run.
