I'm still waiting on ebay for my solder to attach my column to my brew kettle lid (they seem to think it's already delivered
![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
My girlfriend likes bourbon, so I figured I'd do a simple 51/49 corn/barley grain bill. I've been brewing all grain beer for a few years so I thought it would be relatively simple... however my lack of experience with corn made this a bit of a clusterfuck!
![Embarassed :oops:](./images/smilies/icon_redface.gif)
I'm using fine rolled corn - basically grits/flour with the odd larger piece throughout. My dad works at a grain elevator so I get it for free
And the barley was standard malted 2-row from the LHBS. I get it in 25kg bags pre-milled.
Using this chart http://www.brewunited.com/view_page.php?pageid=1 I can fit 28lbs of grain in my 48qt mash tun cooler. So figuring on 14 lbs of corn, and 2 pounds per gallon, I boiled 7 gallons of water in my kettle, shut it off, and started adding my corn. This is where it started to go south.
No mater how finely I sprinkled in my corn, it would float on the surface and then clump up. I spent a bunch of time stirring it in and trying to break up the clumps, but eventually I got tired of that and left the smaller ones, hoping water would eventually soak in. I also made another mistake by turning the heat back on- I thought the convection would help stir and break up some chunks. I didn't have a spoon that could reach the bottom, so as you'd expect, I started scorching it. Once I noticed the burnt particles coming up I killed the heat and wrapped it up to sit overnight.
In the morning I dumped it into my mash tun. It was a little liquidy on top, but the bottom third was somewhat doughy and I'm not sure how well it would have released it's starches. I ended up with probably a pound or more cooked onto the bottom that only came up after soaking for a few hours- it was almost like thick buiscuit-like chunks then. After mixing in my 13.5 lbs of barley, 1 gal of boiling water to get me up into the mid 140s, and leaving it sit for few hours, I opened the drain on my mash tune and... nothing happened. Not even a tiny bit of water would flow out- the corn just coated my bazooka screen and plugged it immediately. I ended up sitting there for a few hours with a ladle and a strainer. Two scoops into the strainer, push it around while the free water drained off, then pressed the grains to get what I could.
In the end, instead of getting 9 gallons of 1.079 wort like I had hoped, I ended up with 8 gallons of 1.061, so only about 2/3s of what I had hoped. Not terrible, but with a boat load of hassle.
I'm thinking that if I us a grain bag big enough to hold everything, I can put a cookie rack or something to keep that off the bottom of the pot while I boil, boil/gel my corn, wrap in a blanket, and when it's cool enough add my barley malt. Wrap it up again and let it convert. Then lift the bag and drain down into the pot, maybe squeeze and/or pour over some sparge water, and then give it a quick boil and into the fermenter. I also think I might get a coarser grind to help with lautering- unless it'll dissolve regardless then I should stay fine to help make the starches accessible?
Lots to figure out... the spend bumps of a new hobby
