I have a couple of different setups that I use but most commonly it is one of two. I either use a 15 gallon keg boiler attached to an 8 gallon thin keg Thumper or if I'm doing a large wash for stripping I swap out another 15 gallon keg Thumper for the eight gallon thumper to increase by stripping capacity.
now when I run my rig I start to get the thumping in the thumper which I'm guessing contains a little bit of methanol and acetone Vapors from the wash in the main boiler. But all of that gas cannot be cavitating. So doesn't some of the methanol and acetone escape and get condensed when I discard the foreshots but then also come through a little bit later, smeared in with the heads when the thumper comes up to temperature and the methanol and acetone in the thumper wash begins to off-gas?
I throw most heads anyway but help me understand. Doesn't using a thumper necessarily mean you will smear some of the methanol and acetone across the heads as the thumper comes up to temperature?
Increased methanol smearing in thumper
- jon1163
