CCVM design approval
Post your builds here.
FishNChips
Post by FishNChips »
I've read quite a bit on building a CCVM, but I just want to make absolutely sure that this design is modular and optimal before I drop the 220+
Thanks for you're help! Pumped to get this thing going. Running gen 2 of UJSSM after I get it built and cleaned.
Here's a quick little drawing. Let me know if it needs clarification.
https://photos.app.goo.gl/TTaM3CcdfNzpN5JE2" onclick="window.open(this.href);return false;" rel="nofollow
Re: CCVM design approval
Looks OK but if its all Stainless steel you should stick some copper scrubbers in the top .There should alsways be some copper in the accending column .
I personally don't like high proof from a reflux still being collected above a gas burner . Can you orientate the liebig and possibly make the spout longer to keep the output at least a few feet to the side of fhe burner . I just know how wasy spillage can be when I'm changing jars .
FishNChips
Sorry, just the tee will be stainless. Yeah, good insight on the proximity of the distillate to the burner. I didn't consider that. I actually already built the condenser, but I may put a little more 2" between the tee and the 90 to increase the distance. Thanks.
Blarney Stoned
Post by Blarney Stoned »
Looks like a VM rather than a CCVM.
kimbodious
Post by kimbodious »
looks fine. I take it that's a dial thermometer? You'll be able to swing the PC out away from the boiler at the elbow
Modular 2" Pot Still
FishNChips
No valve on there. Yes, a dial thermometer. Yep, plan is to put it at a 45.
