Hello all,
I introduced myself about a year ago as I was first reading a lot on the boards. Life got in the way, but I'm finally getting ready for my first build, and am going to do a stockpot pot still w a ss bowl.
I've been intending to go with a worm in a five-gallon bucket in part because it seemed like an easier set-up and also reasonably simple to keep cool through regularly refreshing the water. I like the idea of a Liebig, but it's unclear to me whether it pays off with water consumption.
My plan right now is keep it as modular as possible. I'm going to go with the lock-nut system S-cack has described to attach a 2" male adapter, and then immediately step that down to 1" or 1.5" for the column. The idea here is if I start at 2" then later on I can use the same ss bowl setup to run a boka. But I don't need that diameter on a pot still, so i can make it smaller and cheaper.
I'll keep the column short and then put on my 90* elbow. My plan there is to use a union straight off the elbow for a lyne arm and condensor.
Now, my questions so far are two:
1) is it alright pressure-wise to immediately reduce the diameter tubing right as it emerges from the boiler-lid? I don't see why not, but I'd appreciate thoughts from wiser heads.
2) SS boiler and bowl? ARRRRGGGHHH! Any advice on what to look for when you're buying the material for the boiler? I've seen different type of pots with the top having a small lip running around it where the lid fits IN, but have also seen them where the sides are flat all the way up with no lip. If you're putting on a salad bowl, which type seems more useful? The pot with the lip, so you can clip them together? Anybody have any good combos/set-ups they're working for pot/ss bowl connection? I've see lots on gaskets, tape, and paste, with binder clips or other holding it all together. But I haven't seen a dicussion of how to choose a bowl for a pot, or a pot for a bowl.
Thanks for your thoughts!
Build-plan: pot w ss bowl
savadrava
