What'd ya'll make today?
Shinerfortyniner
Re: What'd ya'll make today?
Post by Shinerfortyniner »
Stripped my second batch of hbb. Didn't smell as good as the first batch. For awhile, I was worried I burned it, but it didn't taste burned.
Hopefully it will turn out well for the spirit run.
OtisT
Post by OtisT »
durty_dunderpants wrote:is there a reason you only go 10"? for me it was just all i have so far! are you capping or just running 1:1 reflux?
I only use 10" of packing because I can only fit 10" of packing in my column without adding the extension. Sometimes I add my sight glass and put a half roll of mesh in the middle of it, just so I have something to watch, so that helps a little too. With mesh 10" of height is the equivalent of 2 extra plates i believe. Maybe I'm only Squeezing heads with what I have and I need more packing to Compress them ;-)
I'm capping, for all intents and purposes. When I'm done squeezing heads I simply turn off flow to the reflux condenser (0 reflux) but I don't remove the coil to add a full cap on the column. It's kind of capped on top with what I call a paddle that holds the coil and I can pot still without much vapor leaking. Not enough to worry me. Otis
jackpinesavage
Post by jackpinesavage »
Just pitched yeast-distillers- into my 2nd attempt at Honey Bear Bourbon this morning. SG 1.035.
JPS
Like a lumberjack but wilder
Ran 3rd generation UJ.
frunobulax
Post by frunobulax »
Yesterday, We made ANOTHER 40 gallon all molasses wash
masonsjax
Post by masonsjax »
Spirit run of some port wine brandy i got from my winery hookup. Finally getting the pipeline refilled.
butterpants
Post by butterpants »
10 gallons RIS + Spirit run on 5 gallons of UJSSM blended to 45% ABV
Texas Jim
Post by Texas Jim »
Finished my 4th stripping run yesterday. So, today is the spirit run. Got about 13 gallons of low wines (80% corn, 12.5% barley malt, 7.5% rye) heating up.
dieselduo
Post by dieselduo »
I made an IPA and piggy back the grain into a take off of UJSSM
Honest_Liberty
Post by Honest_Liberty »
just finished Odin's RyeBread SugarHead...hit the gravity right at 10% but the temp was at least 110 when I took my reading. I don't have a second large fermenter so it had to be split between a glass carboy and primary plastic bucket. 11.5 gallons between the two. I need to find out what that translates to in actual ABV.
Also, I'm a bit surprised. I don't know that I have ever seen the airlock start bubbling within 30 minutes. It's already going at a rate of a bubble every 4 seconds. I can't tell what the other bucket is doing because its open top covered with paper towels in between bacon screens, but I assume it has also started.
Sweetfeed 100 proof for drinking white
All grain bourbon for testing my patience
Whatever else is left goes to the Homefree, because, I hate waste
Beerbrewer
Post by Beerbrewer »
around three litres of Birdwatcher's low wines, I have around 12ltrs all together now so I may take nine and do my spirit run, only concern is not having enough jars to put it all in, nice problem to have though.
Shine0n
Post by Shine0n »
Ran 24 gallons rum wash yesterday, yield 2.5 gal keeper
Today running 20 gal gen 2 corn/barley, still in progress.
The Booze Pipe
Post by The Booze Pipe »
I just got 8 gallons of brown ale from a brewer friend to run through the 'ol booze pipe. Should make some decent wiskey I think. Anyone have much experience stripping carbonated beer? I read it should be good and flat before its ran.
13.5g/50L keg boiler
copper pot still
modular 3" CCVM copper&stainless w/offset gin head
jon1163
Post by jon1163 »
Working on 20 gallon batch of a cerarye bourbon. Smells just a little bit like heaven
butterpants
Spirit run on 13 gallons of corn squeezins low wines. Real slow through fores and heads. Took like 8 hours.
Hilltop
Post by Hilltop »
Running my low wines off a barrel of sugar wash. Pureed a 5 gallon pot of bananas to put in the thumper tomorrow on the spirit run. While I was at it i used 20 gallons of my sugar wash hot backset to get a new barrel of cooked corn, oats and wheat to Alpha Amalaze temp. Long day today and gonna be a long one tomorrow. :|
"Virtute et armis" By valor and arms
Let's keep our country free as God has given us.
"Give me Liberty or Give me Death."
Beerbrewer
Did a spirit run of 6ltrs low wines of Birdwatchers and got 3ltrs for the cuts which I will do tomorrow.
dieselduo
Post by dieselduo »
Made a Chinook SMaSH and piggy backing a single malt sugar wash
Celis
Re: Cornflakes whiskey
Post by Celis »
Doing the first stripping run of Odin ryebread whiskey as I am typing this. Couldn't resist tasting it and it's great already!!
distiller_dresden
Post by distiller_dresden »
mashing in my first deathwish wheatgerm, modified somewhat-
6 lbs DME
1lb Lyle's black treacle
64 oz peach mango 100% juice
5 lbs homemade invert (make 10 lbs batches once a week for my liquor needs, so)
adding 1lb caramel 60L in the last 30 min of the wheatgerm boil
I read, I write, I still.
OtisT
Post by OtisT »
I started my first ever peated whiskey today.
* 42% Peated Malt Barley
* 58% "CBW Bavarian Wheat" Liquid Malt Extract (65% malted wheat, 35% malted barley)
31 gallons, OG 10 60 Pitched last night and it's been bubbling all day long.
What wonderful smells. :-)
Otis
likker liker
Post by likker liker »
OtisT wrote:I started my first ever peated whiskey today.
Otis
Sounds fantastic, I've been thinking about starting another batch
Beerbrewer
Stripping run for 20ltrs of Birdwatchers, got 3.5ltrs of product.
Honest_Liberty
Spirit run, first one yet with a bunch of SF low wines and some that didn't oak well. I'm shocked at the amount of product from 13 gallons at 40%.
Been at this since 10am, still collecting all mid 70s, and it's 7pm, although my proofing hydrometer has been verified at 2% over at 95%, and it showed 46% at 43
Beerbrewer
20ltrs of Odins Cornflake Whiskey and 1.8ltrs of Odins Easy Gin for dilution tomorrow.
jon1163
Post by jon1163 »
I have a gallon and a half of Still Life's rye distillate waiting and just mashed out 18 more gallons all in anticipation of filling a new three gallon barrel....getting hyped
Beerbrewer
Just finished a cornflake whiskey spirit run using 6ltrs of low wines. Got about 3.8ltrs going fairly deep into the tails. Making a pale ale tomorrow and the cuts on the spirit run. Always happy when I have a productive day. :D
Hilltop
Post by Hilltop »
Had a half a barrel of sour mash that was ready 6 weeks ago that I never finished running sitting outdoors, so I opened the barrel and saw a good lacto infection going and decided to run it. The proof has dropped from evaporation I guess. Last run of this she started at 160 proof, this run was 130.
Around 105 proof I tasted her and it has a very interesting flavor, nutty with an oaky hint. Gonna strip it down and add it to my all grain low wines. Should be an intetesting second run.
6 Row Joe
Post by 6 Row Joe »
I just put a couple quarts of Uncle Jessies Sour Mash on oak. After a month on oak there's a very nice product.
Beerbrewer
Ran a feints run, stopped collecting after I started smelling tails, I've already recycled my feints once already so didn't want to chance wasting time and effort for a third run.
