Domestic crisis
- rubelstrudel
Domestic crisis
I am pulling my cooling water directly from a shower mixing battery. Today I forgot to make sure that the mixer dial was all the way to the blue side, and our hot water tank emptied into my cooling water. So when the wife woke up after a lazy saturday morning and was about to take a shower, there was no hot water, the shower was freezing cold.
So the wife did as wives do... she yelled for me, shrieking. And I cam running up from the lab thinking a mad axe murderer is coming through the wall, or a spider or something.
I come up and do some preliminary ho hum ho hum. And since I can't admit that it is the still that has eaten all the hot water, I have to go looking around in the fuse boxes, and I proclaimed that the fuses had blown and she had to wait for the tank to heat up again.
It didn't help. It was of course my fault her day was ruined. But at least she hasn't veto'ed my hobby yet.
Always impatient. But learning.
Re: Domestic crisis
Smooth
You have enemies? Good. That means you've stood up for something, sometime in your life.
Winston Churchill
Winston Churchill
Re: Domestic crisis
um... yeah... but it's a gas heater.
now i drink for evil.
Re: Domestic crisis
hahaha I love it
Re: Domestic crisis
Nice save!
Swedish Pride wrote:
- rubelstrudel
Re: Domestic crisis
I have now removed the shower mixer to avoid future mishaps. Instead I have installed a valve on each of the hot and cold water pipes. Doesn't look like much but now there is no chance that hot water will leak out in the cooling water.
Re: Domestic crisis
Nice one !
Did you lose much booze ?
- rubelstrudel
Re: Domestic crisis
No. The booze is safe. Originally I extracted 9.5 litres of pure 96% into 20 cut bottles from my 23 litres of low wines. Then I had to shut down the still for a while while I figured out a way to blame the shortage of hot water on something else before I added my feints jar to the boiler and ran to the end. This resultet in another 3 liters of azeotrope. Of the original run I saved 7.5 litres. From the tail-run with added feints I discarded the first litre, but I am still undecided about the last two bottles. Originally I meant for this to become technical spirit, but the quality is so good, that I might end up keeping it in the "good enough for flavoured vodka" category.
Here is 7.5l of good stuff +2l of stuff I will decide on after a few days of airing out. After I have combined two and two cuts into full bottles, and ditched the 2 first liters as heads.
The heads and the rest is in the technical spirits locker, used for cleaning and starting fires.
I am however starting to see why not everyone are running fractioning columns all the time, even for neutrals. This run was started 0900 and ended 19:30. Thats a lot of hours bubbling along in the lab. In potstill mode I could have run everything through twice in that time, if not more.
Re: Domestic crisis
Too bad you couldn’t use the product condenser coolant water outlet to fill her a nice hot bathtub....you’d have been the knight in shining armour.
Got lemons.....make lemonade.
- Copperhead road
Re: Domestic crisis
Got lemons.....make lemoncello.still_stirrin wrote:Too bad you couldn’t use the product condenser coolant water outlet to fill her a nice hot bathtub....you’d have been the knight in shining armour.
